Wiggler wrote:I'm getting ready to start this project... can anyone else chime in on this? The only other thing I thought might be different is the triggering voltage from the ECU... does anyone know if they are different on a Maxima vs. Y33?
you stated "solenoid" in your first post, but the 3 hose connx (one on the bottom, and two at a 90° angle on top?) sounds like the EGR BPT (back pressure transducer) is the bpt for the vh41de no longer avail? i replaced one once on one of the vh45de's and memory says they look the same. you can test the BPT you know?
edit:ah slap me silly-just re-read the post and you mention the elec connct. ok, yes you got the solenoid which connx to the BPT. i don't know conclusively. but i'd be surprised if you can't source a new one from IoS. the principle of the solenoids is the same, but the connx might be different across the different platforms.
