Davis4ChristNY »
https://forums.nicoclub.com/davis4christny-u218362.html
Sun Apr 14, 2013 9:29 pm
Right. I had a technician give me a diagnostic tip on the egr valve. The diaphram being held open caused the vehicle to stall, and there was full movement in the diaphram. Is he full of crap in his diagnoses? Or like I said could the egr code be tripped because of the system issue the Nissan has sent out service bulletins about? I saw it with my own eyes, although do not have a copy on me. But they admit that the system in this year model and some others I believe have connection issues or something is wired wrong, or whatever, but it the bulletin said the ecu will throw codes out that are not supposed to be. And I do believe that the knock sensor, temp sensor, and the egr valve were included in a list of codes that could potentially be registering on the ecu, but not in need of repair... The egr valve is behind the engine on the driver side correct? I know it is completely different, but that bulletin has me thinking since I did the quick diagnoses a tech told me to do to test if the egr valve is working correctly, its just the error of the ecu sending out codes it shouldn't be. And I know that the hoses are rotted out, I have known to test the canister but have not done so because I have not been able to get underneath her. I have limited tools, as my adult life started late, cause I was a moron when I was young... Anyways, the vehicle does not surge, the rpm's were just way to high for any position of the transmission, drive, neutral park.... And there was a little bit of play in the cruise and throttle cables, but I tried to tighten them and they would not. Is there supposed to be absolutely no play in those cables? And would this cause the accelerator peddle to be stuck, requiring me to literally kick it to be able to give the vehicle gas???
