Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Mon Jan 06, 2003 11:57 am
In my experience, most of the clogging occurs inside the plenum port, not the valve or tube. You can double check this by removing the sensor that screws in to the plenum in that port. Mine had a very thick (85%+) blockage in there. I've used carb cleaner and brake parts cleaner for this before, but the best stuff I've seen is by BG and it's called throttle body cleaner. If you car has never had the plenum removed and hand cleaned, it's well overdue! Just be sure to have all of the rubber hoses to replace under there if you go that route.
I think one of the main symptoms from a non functioning EGR valve is detonation (spark knock). The cylinders tend to run hotter, so you can have all sorts of side effects. If the knock sensors are detecting knock, the ECU is retarding the timing advance, so that could have something to do with your power loss.
Good luck!
Heath
