gordonliu »
https://forums.nicoclub.com/gordonliu-u37714.html
Thu Jun 10, 2010 12:47 pm
I have a 1992 240sx. The CEL is on (solid). I have attempted to put the car in self diagnostic mode, and I am having some trouble.
I have attempted to turn the screw to Self diagnostic mode, wait, then turn it back, many many times, with the car or off, or off then on, or on then off.
1) I turned the car off (Car was already hot), turned the screw all the way to the diagnostic mode...
the bulb inside the ECU window remained solid red.... waited.... nothing changed, still Red...
turned it back to normal (counter clockwise), bulb still solid red, CEL still solid orange
2) turned car on (screw still turned all the way to left), then turned the Screw all the way to the Diagnostic mode...
ECU lamp remained solid red... waited... nothing changed, still red....
Turned it back to normal (counter clockwise), lamp still solid red, CEL still solid orange
3) with car off, turned ECU screw to self diagnostic mode.
THEN I turned the car on (turned the key while the screw was set on self diagnostic mode)
lamp remained solid red... CEL remained solid Orange... Waited, nothing changed.
turned the screw back to normal, waited, nothing changed.
4) disconnected the car from battery. waited 30 minutes, came back, attempted 1-3, all the same results
5) disconnected the ECU from the car, waited 30 minutes, came back, attempted 1-3. all the same results.
It sounds like my ecu is f*** up.
any thoughts?
