I have that same picture, but is that the diagram used to connect a piggyback ecu?ltsnotme wrote:
I found it!ltsnotme wrote:I haven't had any experience with installing piggyback ECUs, but depending on the installation instructions for it, you'll probably need a pinout diagram for the ECU connector, such as this one for my '96:
It's in the FSM, but I don't have the one for your year.
I dont know..I will call the tuner tomorrow and ask him if this information is enough so that he can make the connections...thanks man you really helped alotltsnotme wrote:What do the instructions say? Are you supposed to splice it into the ECU harness?
PathPro2002 wrote:I found it!ltsnotme wrote:I haven't had any experience with installing piggyback ECUs, but depending on the installation instructions for it, you'll probably need a pinout diagram for the ECU connector, such as this one for my '96:
Where the pic go I need the ecu harness and pinout myself for 2001 pathfinder
What else do I need now?
