white_g35
white_g35 wrote: ↑Thu Aug 31, 2017 12:47 pm
2003 G35 6sp MT w/ Brembo
I need to replace my ECM because it keeps shorting out the O2 sensor in bank 1 (per my mechanic).
You appear to be putting a lot of faith in "per my mechanic"
If you and he have not followed the troubleshooting steps in the FSM how do you know for sure exactly where the problem is?
Get a second opinion preferably from an Infiniti trained technician that has the proper tools for a proper diagnosis before guessing and just replacing parts.
How do you know that the problem is not in the wiring harness or its many connectors that is the cause of the short?
Was your vehicle ever involved in a flood?
Telcoman
