180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Aug 22, 2005 4:17 am
The ones I've installed from ebay had fitment issues. Not all the holes lined up and so on. The aluminum, if you take brake or carb cleaner to it will come off like a metallic paint with sparkles and stuff. Not exactly the best stuff for your ride. If you can, get the Greddy one. If the motor's out, give the ebay one a try since it'd make the fitment a bit easier than if the motor were still in the car. Another thing you might have to worry about is where the baffle meets up with the lower oil pan, several of these ebay pans I've installed needed to be fitted around the baffle ie grinding and stuff. Not all that fun if you're under your car with oil dripping down.
