eBay Foglight thread
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
williamk10
Car: '07 Nissan Versa SL
In light of my rock chipped, burnt out and poor light output Walmart foglights, I decided to buy a set on eBay and see how they perform. They are OEM replicas. Pics are below:
Comes with wire harness, OEM look foglight switch, zipties and instructions
Flat beam pattern. These are actual fog lights, compared to the driving lights from the Walmart thread
Button lights up when on, looks nice
I will be installing them soon and will post pictures. I know of one problem I am going to run into. Trying to get the harness thru the firewall. :cry:
NODES
Car: 2007 Nissan Versa SL (Blue)
what was the cost of those? Is there mounting hardware for our bumpers?
williamk10
$99
Installation done. This kit comes with OEM plastic shrouds. The fogs don't fit the best. They mount with a screw and they will hold tight but the shroud does not sit flush up against the foglight. There is a slight gap where water and dirt will accumulate. Will take better pictures later. Also, the button does not fit on the dash where the blank button sits. It is too big to fit the opening
anthony870
Car: '11 Nissan Juke S 1.6L Turbo
'09 Nissan Versa S 1.8L H/B (traded)
i saw these on ebay but was not sure if they would fit in factory wiring harness. my versa is prewired. are the bulbs for these h8? how are the quality of the housings? i bought a couple of oem housings came from china. they wound up melting from even regular bulbs. thought at first it was from set of silver star bulbs but put a set of regular bulbs in and still see them start smoking after a while of use. done buying from china. have you had any problems with these smoking?
williamk10
uh, they have been on my car for about 4 hours so i'll tell you in a week :p
anthony870
Oh sorry. Didn't look at how old the thread was. Lol. Do they use the h8 bulb?
NODES
anthony870 wrote:Oh sorry. Didn't look at how old the thread was. Lol. Do they use the h8 bulb?
aren't fog light bulbs H1 or H3?
williamk10
Its not an H3, thats for sure, although conventional foglight bulbs are H3. these ones are longer and have a 90 degree bend in the connector, more like an H1 I suppose. I took some better pictures of the final installed product:
OEM foglight covers with the aftermarket lamp. Not that bad of a fit, now that I think of it. Slight gap between the lamp and the cover. Not sure how the OEM fits, need to look at one to compare
And it turns out the button fits! Very well I might add. I didn't think to insert the button the same way the blank button came out...duh
Last shot with the light pattern. Even, unlike my attempt with the Walmart fogs.
In conclusion, for $99 ($40 shipping tho), not bad, expecially if you cannot afford the OEM set. I wish the plug for the bulb was more secure. A simple twist and the bulb will fall out. Not sure why a bump clip wasn't part of the design to hold it in place. Time will tell how well these ones perform. Rainy season is upon us in Vancouver so they'll get a good test this Winter.
anthony870
NODES wrote:aren't fog light bulbs H1 or H3?
The versa oem wiring harness is for h8 bulbs. I've heard that it is a odd bulb size.
If these are h8 bulbs then I may get them just for housings depending on quality. Nissan wants 147 a piece for housings. So this would be like getting 2 for the price of 1.
NODES
did it come with the foglight finishers? or is it new ones from the dealer?
williamk10
It came with OEM ones. I've been calling them housings or shrouds, but yeah, comes with OEM ones.
JayyV09
Car: '09 Nissan Versa 1.8L SL (Super Black Hatchback)
nice job broo
williamk10
Thanks man. Its a good buy, i recommend it because the OEM ones are so expensive. These ones give you the OEM look for a fraction of the price. A stand alone button is also a bonus for when you want the fogs on but not the headlights.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
the small gap from lense to finisher is normal. Mine have it even though I cut my finishers.
They look good. The spare set of foglamps I have in the garage have H11 bulbs (blue label and 90° connector). I think they are the same I have in the car right now.
BigBodyV
Car: Nissan Versa S
Hey dude how was the wiring?
williamk10
It was fine. Got the fogs in, ran the wire to the fogs and then back thru the firewall and into the switch where my dash is. Very standard and easy to understand.
BigBodyV
Car: Nissan Versa S
Oh ok and how you conect its power source? Directly to the battery?
williamk10
The instructions say to wire it directly to the battery. However, if you do that you will have to turn it off everytime you exit the car or else it will stay on forever. Instead, I have power hooked to a power source that only comes on when the key is in the ignition. That way, it will turn on when I start the car and turn off when I turn off the car.
NODES
williamk10 wrote:The instructions say to wire it directly to the battery. However, if you do that you will have to turn it off everytime you exit the car or else it will stay on forever. Instead, I have power hooked to a power source that only comes on when the key is in the ignition. That way, it will turn on when I start the car and turn off when I turn off the car.
which power source and or fuse did you hook up to for them to turn off?
williamk10
the fuse box in front of your left knee when you're in the driver seat. There is an accessory fuse there. I used an add-a-circuit there for switched power.
NODES
williamk10 wrote:the fuse box in front of your left knee when you're in the driver seat. There is an accessory fuse there. I used an add-a-circuit there for switched power.
thanks, will do the same.
FGVersa
Car: 2010 Nissan Versa
1998 Ford Mustang GT
1996 Mazda B2300
hey williamk10 im looking to get this same kit for my gfs versa. i got everything u said but except for when u said u used an "add-on-circuit." so what fuse slot did u hook that power source into? it would be great info so i can hook hers up exactly like yours. thanks again and great pics. I cant wait til i do this for her car.
kpmh
Car: 2011 Versa 1.8S
I just hooked the same kit up over Thanksgiving. I used the radio fuse. Everything works great. Just an FYI, I tried to take off the plastic cover off under the engine to run the wire loom behind the bumper but I gave up. Couldn't get it off. I lengthened the wires and run them up in the frame in front of the radiator around the hood latch. A few zip ties took care of keeping them off the radiator and tucked away. Tied everything together with zip ties to the wire harness by the right hand hood hinge, near the battery. From there ran the switch wires and positive thru the fire wall and reconnected everything inside the car. Note you'll have to add about 2 ft to each wire including the passenger side fog light wires and the wires thru the fire wall if you run it like I did. The switch blank is a pain to get off. You need to work at it. It slides out towards the front of the car. Insert the new switch from the back towards the rear of the car. It fits perfectly and snaps into place. It helps to take out the mirror switch and you can see what you got. Push on the top of the mirror switch and work it out to towards the front of the car. Don't force things, they'll come out eventually. Good luck.
FGVersa
1996 Mazda B2300
kpmh wrote:I just hooked the same kit up over Thanksgiving. I used the radio fuse. Everything works great. Just an FYI, I tried to take off the plastic cover off under the engine to run the wire loom behind the bumper but I gave up. Couldn't get it off. I lengthened the wires and run them up in the frame in front of the radiator around the hood latch. A few zip ties took care of keeping them off the radiator and tucked away. Tied everything together with zip ties to the wire harness by the right hand hood hinge, near the battery. From there ran the switch wires and positive thru the fire wall and reconnected everything inside the car. Note you'll have to add about 2 ft to each wire including the passenger side fog light wires and the wires thru the fire wall if you run it like I did. The switch blank is a pain to get off. You need to work at it. It slides out towards the front of the car. Insert the new switch from the back towards the rear of the car. It fits perfectly and snaps into place. It helps to take out the mirror switch and you can see what you got. Push on the top of the mirror switch and work it out to towards the front of the car. Don't force things, they'll come out eventually. Good luck.
thanks man. so did u use a fuse tap on the radio fuse? and the blank switch has tabs on the back right> just squeeze them til it pops out or no? btw whats the bulb type of the fog lights?
FGVersa
1996 Mazda B2300
so i bought the kit for my gf versa with HIDs from DDMtuning.com. she cant wait til i get them on. i will post pics when i do get them installed. and btw the BULB TYPE FOR THIS KIT IS A H11.
anthony870
FGVersa wrote:so i bought the kit for my gf versa with HIDs from DDMtuning.com. she cant wait til i get them on. i will post pics when i do get them installed. and btw the BULB TYPE FOR THIS KIT IS A H11.
i just found out yesterday that h11 bulbs are interchangeable with h8 bulbs. so this kits housings will also work in the prewired versas. I may be getting them soon because 100 for 2 housings is a lot better than 147 a piece at the dealer. i already have the oem switch, which is about 100 at nissan. so for 200 you can have a set that would cost over 400 at nissan.
kpmh
Sorry, haven't been able to get back to you before. Yes, I used the radio fuse. The add-a-circuit pops into the radio fuse slot. It has two slots for fuses - one for the original radio and one for the new circuit. The blank has tabs you have to squeeze until it pops out.
http://ecx.images-amazon.com/images/I/1 ... AA300_.jpg
FGVersa
1996 Mazda B2300
so u put the radio fuse into the add-a-circuit and then for the fog light fuse how many amps did u use?
kpmh
I could only find a 10 amp add-a-circuit and the radio fuse is 10 amp anyway, so I used that. Seems to work fine.
FGVersa
1996 Mazda B2300
so do u use 2 10 amp fuse or just one for both the fogs and radio? or one for each?
Return to “Versa Technical Discussions”
