Yea, I'm actually doing it this weekend. I've done a few drain and fills over the past couple weeks to flush out some of the older fluid and I used Pennzoil Synthetic ATF (which btw they don't make anymore). But since it's on clearance, its pretty cheap around here, much cheaper than M1-ATF so thought it would be a good choice to clean out the older fluid. But I was gonna use the M1 after I did the pan drop. So you're saying it wasn't shifting right using the M1? I know one of the benefits of using it over regular Dex is that it's supposed to keep the temperature about 10 degrees cooler, which obviously can help extend the life of the tranny. But now that you say you didnt like how it shifted afterward, I'm wondering if maybe I should go with Amsoil or RP or some other compatible synthetic3Q Jay wrote:of course its messy!
but you gotta do it at least once so you can replace the filter and clean the magnets.
Owner--I see you are using the M1-ATF. I used it very briefly 9 years ago but did not like how slippery it was between shifts. maybe off topic but what is qship and everyone else running? Dex III is really hard to find now, and I'm not quite ready to put in Dex VI without some empirical data on shift quality AND leakage (different synthetic add pak is not compatible with all seals particularly Viton (which i don't really know if the RE4R0#A has or not)).
Sounds good to me. I think I might in fact try the Redline.qship96 wrote:I have used Redline D4 synthetic ATF for most of the 305,000 miles and so far it is still operating like new.
Are you sure they *still* sell it? I always bought my Dex III there until about 2 years ago, now when carefully looking at the supertech label it says something like.....blah blah, previously serviced by Dex III....justjuiceit4 wrote:Walmart sells Dexron III in gallon jugs for IRRC less than $15. Dex III is actually really good stuff compared to the ultra thin stuff OEMs put in their cars nowadays. I work for a major OEM and all the "DIY" guys there do not use the factory recommended fill and use DEX III instead! .
