johnnyballs180 »
https://forums.nicoclub.com/johnnyballs180-u106780.html
Mon Oct 13, 2008 3:46 pm
the t25? mine became a really good door-stop... that's about all it's good for now, so i don't have it in front of me. i didn't try to put the s14 elbow on it, but seeing as how my s13 elbow fit right up to the t28, i'd imagine it should work just as well in reverse. again, my only issue initially was the gasket. it overlapped one of the holes (for the bolt, not the stud), but i was also using an s14 gasket. maybe it was just a fluke, but worst case scenerio, you could punch out or drill out that hole, if you end up with the same issue.good luck, and fill us in with your progress?
oh! i just thought of something. since you're probably going to be in that area, you could just take off your old elbow, remove the gasket between it and the turbo, and when you're shopping for an s14 elbow, just align the gasket up with it. that's way easier than taking out the turbo
