extra stuff
http://forums.nicoclub.com/zer...d=230
i'm about 99% that you're wrong about this. I'm only pointing this out because i don't want people getting the wrong idea and thinking E85 is a magic fuel or something.RM12577 wrote:with a properly configured car with everything set up specifically to run E85 it will get at least the same if not better gas mileage while producing a higher horsepower
Thanks going back to the dyno today hopefully to see if I can make some more.r34 gtr wrote:^ Those are some impressive numbers in your sig man.
You do make more power with it depending on what fuel you were using before. I made power going from 100octane to E85 and changing the tune. My gas milage did go down but not to much.iliketocrash wrote:
What the?! You've been running e85! That's pretty cool Ryan. I've missed out on a lot of things here on the forum ever since my computer and camera died. I'd like to see some pics of the setup and the s14!float_6969 wrote:I ran my car on E85 for about a year. Once I get it back into the S14 it will run on E85 again.
My motor is high compression and turbocharged. This situation creates a large demand for high octane fuel to prevent detonation. E85 is the most economical and practical route for me. I have a standalone and can easily tune the car to accommodate the differences between the fuels.
E85 will make more power if your engine isn't running optimal timing and boost due to the constraints of the pump gas available.
E85 will get poorer gas mileage. How much will vary based on your tuning. Since it has a higher octane, you can run leaner AFR's without detriment. Compared to gasoline in our particular engine, with a proper tune, you should get about 10-15% less miles to the gallon. The leaner AFR's increase NOx emissions. If emissions are of concern to you, then 2 catalytic converters in series will probably alleviate this, or you can tune the motor for stoich. for the sniffer test and then change it back.
If properly designed, an ethanol only vehicle should make the same power, with better fuel economy than it's gasoline counterpart. Ethanol's higher octane rating allows for designing an engine with higher volumetric efficiency. This mean an engine specifically designed to run on ethanol, can utilize a smaller engine, with higher compression, and possibly forced induction that would never be possible with gasoline. This allows for decreased fuel consumption at the same power levels.
My CA build-up thread:
http://forums.nicoclub.com/zerothread?id=185406
E-mail:
davidricardo86@yahoo.com
Yeah i'm still alive. I dont have a home computer anymore so i dont get a chance to get on here as often as i'd like. Also the camera i was using for my build finally broke (i sat on it). I do have a PS3 that i use to go online but i dont have a keyboard and it basically sucks as a regular computer. I'll be buying a camera and laptop in the near future so i can start updating and posting again. I still lurk and read what people are posting though!ks13 wrote:David your still alive!
how come we never hear from you anymore, is everything cool?
float_6969 wrote:I think we're up to 5 stations in a city with a population of about 130K ppl. The physical size of Topeka isn't very big either. I can drive through town and cover the city end to end in maybe 20 min. That's not using any highway's.
So yes, it's readily available here, LOL.
I've been curious about the fuel for a while. Do you have a link to some more info about making the swap?RM12577 wrote:yea only one station here in town but its only like a mile from work for me so whenever im at work ill just fill up, the only time it might be an issue is when i go on vacation but i have another car and my motorcycle so i should be fine. I'm going to see if i can get HEB to put in more E85 stations than the one they currently have because usage has gone up quite a bit....
