Larz wrote:Thanks Vos and AZ for asking that question and answering it!
I've been tempted to do this for some time now. Recently I had the trunk liner removed to upgrade the license, cargo, rear turn signals, and reverse lamps and i was disappointed to find there was virtually NO sound deadening material in the trunk.
I'd like to do the entire trunk and the interior floor, but not quite sure I want to dismantle the doors (afraid of wrecking little tabs or damaginf trim pieces that are nearly 6 years old now.
Do you remember how much Onyx you used when you did your car?
Just measuring in my head I reckon about 50 sq ft should do the sides, bottom, and lid of the trunk + the entire interior floor area? Would you agree?
Deal. I'll let you do it firstLarz wrote:Great tips, Fezzik ! Thanks. I agree - if I'm going to do it, I want to do it all on the first try. Never want to find I'm sat there with no product and more spaces to cover.
Whomever does it first MUST do a DIY or at least keep track of which areas they did and the total amount of Oxnyx they used. deal?
Let me know what you find, it would help everyone out. I have a feeling this project is going to be a team effort with some people doing a write up, some doing measuring, etc. Let's do it!yosM45 wrote:I'm thinking 100 sq. ft. Should cover the doors, floors, back of the second row, and deck.
But I'll measure.
Or the Butyl Onyx stuff from GTMat which isn't simple tar and tin foil.TDot wrote:dynamat has a few products so I don't know exactly which one you are buying, but I'm going to assume you are looking at the line that everyone buys the "tin foil with tar on the bottom". dynamat (or deadener of any type) is NOT what you buy for reducing noise from a car. they are meant to stop rattles and vibratios. if you are looking to quiet your car and prevent noise ingress and egress then you need to buy mass load vinyl (mlv) and foam liner. only that will truly reduce noise.
Ahh I missed that first part.Larz wrote:Regarding door panel removal. The FAQ about removing trim pieces shows how to remove front doors with pics - and it says rear doors are the exact same as the front.
Regarding the rear deck, I'm thinking that after we remove the entire trunk liner, the deck will be exposed. We can place the deadener on the underside of the rear deck from inside the trunk and possibly also cover the rear seat backs as well. If I'm wrong, someone please correct me.
Thanks TDOT ! That's a very good point. We are looking at GTMAT Onyx Butyl. Here is the blurb they have on their website:TDot wrote:dynamat has a few products so I don't know exactly which one you are buying, but I'm going to assume you are looking at the line that everyone buys the "tin foil with tar on the bottom". dynamat (or deadener of any type) is NOT what you buy for reducing noise from a car. they are meant to stop rattles and vibratios. if you are looking to quiet your car and prevent noise ingress and egress then you need to buy mass load vinyl (mlv) and foam liner. only that will truly reduce noise.
That's the kit I'm considering as well, if 50 is enough.Larz wrote:Thanks TDOT ! That's a very good point. We are looking at GTMAT Onyx Butyl. Here is the blurb they have on their website:TDot wrote:dynamat has a few products so I don't know exactly which one you are buying, but I'm going to assume you are looking at the line that everyone buys the "tin foil with tar on the bottom". dynamat (or deadener of any type) is NOT what you buy for reducing noise from a car. they are meant to stop rattles and vibratios. if you are looking to quiet your car and prevent noise ingress and egress then you need to buy mass load vinyl (mlv) and foam liner. only that will truly reduce noise.
GTMAT BUTYL ONYX Sound Deadener is made of real, true Butyl material that can withstand higher heat than regular asphalt material. Not only can GTMAT BUTYL ONYX Sound Deadener withstand high-heat, but it gives off no odor! Additionally GTMAT BUTYL ONYX Sound Deadener reduces unwanted rattle and improves the sound of your stereo with the 70Mil Thick Real Butyl Material. Give GTMAT BUTYL ONYX Sound deadener a try today and see why our customers choose GTMAT Sound Control for their sound deadening needs!
They make a 50sq ft kit that includes degreaser, a roller, and instructions for $159 US. What are you thoughts?
GTMat wrote:I don't think I have heard from either of you. You guys are aware you get a slight discount right? Give us a call! 1-855-GTSOUND -Tracie
Sending you a PM with pricing info!yosM45 wrote:GTMat wrote:I don't think I have heard from either of you. You guys are aware you get a slight discount right? Give us a call! 1-855-GTSOUND -Tracie
Im still planning on doing this. I just won't be back home from work until June 7th.
It was suggested that I should measure what I want covered, which as of now is all 4 doors, the front and rear floors, the back seat rest, the back seat deck, and the trunk.
Quite a bit.
The hardest part of all this is getting to the floor boards. Not looking forward to this.
Which product did you all recommend for the noise deadening.
Sounds good, we look forward to hearing from you!Larz wrote:GTMat wrote:I don't think I have heard from either of you. You guys are aware you get a slight discount right? Give us a call! 1-855-GTSOUND -Tracie
No, I wasn't aware of the discount and thanks for letting us know! I'm in the middle of a few other things around the house at the mo, but when i'm ready to start this mod I will contact you.
Thanks again !
Floorboards are simple. You're going to be removing most of the interior anyway (that's the only way to give it a REAL good cleaning). Seats, trim panels, console, carpet - in that order.yosM45 wrote:
AZhitman wrote:The density of the butyl products not only stops resonance and vibration, but it is an effective barrier to transmitted sound (such as tire noise). Foam presents its own challenges to the installer, and if you only have 1/16" - 1/8" of space in which to install something, it needs to kill the major noise FIRST (resonance / vibration).
Actually, all I did was the trunk and yes, I noticed a difference. My main trouble was rattling of the rear deck from bass notes with the music turned up. I fixed that by painting tennis 2 tennis balls black to match the color of the deck lid. I smooshed them in between the rear windscreen and the sides of the upper mounted brake light and that took care of the rattling. I now that isn't what you were hoping for, LOL, but that's all I did.dball wrote:sorry to revive an old thread but Larz did you feel this made a big difference? between the exhaust, the sound system and just the overall aging of the car there are creaks and rattles and drone throughout the cabin and this product looks promising...
do we still get a discount? and how much would we need like 50 square?
