Dunlop SP 7000 Directional?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
CDNicecube
Car: 2010 EX35 Journey+Tech+Navi
Hi all
So I have the OEM Dunlops on a 2010 AWD EX35. I am doing their rotation and I noticed that the Infiniti manual says to rotate only "front to back", on the same side.
Yet, the tires are none directional (at least there are no indication of that on the tires or on the web). A web search tells me that they are asymmetrical. fine. The tire identifies an inside-outside wall.
I would much prefer rotating then in criss cross, as normal tires.
Are the Dunlops non directional? If so, can I rotate them as normal tires Right to left and back to front? I would assume this would extend the life of the tires...
Thanks all
Ice
bigbenex35
Car: Ex35
I would say yes...
CDNicecube
You mean we can rotate them right to left and criss cross? Not sure "yes" to which question....
bigbenex35
Car: Ex35
You can rotate them from left to right
CDNicecube
Thanks. This is what I will do this Sunday.
EXceptional
Car: 2008 Aspen Pearl EX35 Freakin Loaded!
Yes, criss-cross them to gain whatever life you can out of those crappy tires.
Start saving some money for their replacements.
How many Kilometers do you have on them?
CDNicecube
I just got them on today (took the winter's off).
I have about 25,000 km on them. Perhaps less. I still have about 6 to 7/32th left, based on a tread gauge.
What do you all recommend as replacements? I'd like a quiet tire that performs (if there is such a thing).
EXceptional
The Michelin primacy MXV4 is the best seller... and the ones that most people here on NICO use as a replacement for the Duncraps.
http://www.tirerack.com/tires/tires.jsp ... %20Journey
Recently, some people are installing the Michelin Defenders, but despite the fact that they fit, they do not come with the OEM's speed rating.
http://www.tirerack.com/tires/tires.jsp ... &tab=Sizes
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
