mcastro »
https://forums.nicoclub.com/mcastro-u22582.html
Fri Jul 20, 2007 10:14 am
Help needed….
I am at a bit of a standstill and need some thoughtful advice regarding a problem I am having with my 95Q. My front driver’s side door will not open-- it appears I have a problem with the door lock actuator, or one of the switches or mechanisms inside the door.
In order to repair, or even to give it a good diagnosis, I need to get the door open (to get the inside panel off). Here’s a description of the behavior:
The inside and outside door handles act as if the car door is locked; pulls with ease and with no resistance. No change is felt when the unlock sequences are gone through using the remote, the lock/unlock switch, lock knob, or key. The inside lock knob appears to not quite make it all the way to the normal open position (about 80% ) when you try and unliock. There is some resistance when pushing it the rest of the way; doing so causes all door actuators to lock. Using the remote, the first “unlock” causes the driver door actuator to “unlock” (it is audible), however, no open door. The second “unlock” with the remote cause all doors to unlock, however, they immediately lock (curious symptom....something is prompting that). The inside door lock/unlock switch has the exact same response, it unlocks all doors with an immediate lock of all doors. When this first happened, I was able to open the door using the key, but now it basically has the same effect as the remote. Random combinations don’t work….. The theft prevention cycle seems to work fine, and all other visible functions seem to be working (interior lights, etc.)
After I opened it with the key I initially thought that maybe some lubrication was needed to the locking mechanism; did that and everything worked fine for a couple of days. Yesterday, I was trying to close the door, after getting in the car, and the door latch would not catch/grab the latch bar with the door was in the fully-closed position. After a few open/close cycles on the door lock/unlock switch, the latch engaged. But that was it; the door handles do not respond, the door remains in stubbornly in the closed state, and I have resort to embarrassingly crawling through the other doors into the driver’s seat.
The FSM gives me an idea of how to diagnose what might be wrong, but I need to get the door open to get the inside panel off. It feels like an electrical or electromechanical issue, as opposed to a mechanical part, but am at a loss.
Ideas and thoughts are appreciated!
