GRed »
https://forums.nicoclub.com/gred-u132848.html
Tue Apr 15, 2014 7:11 pm
Here's his post
Road Ruler wrote:
Things got so bad for me that the low battery voltage caused my main computer to need reprogramming - at a cost of 180 dollars.
The radio, the install kit and the installation cost me about 700 dollars.Toss in the 180 dollars for the reprogramming and the cost of a couple of batteries and this whole mess cost me 1000 dollars.
BTW...the Bose radio in 2003 G35's comes from Clarion. "
Although I do not know you personally I feel that the majority of people with the ability to trace down this type of concern including a current draw test should be able to install a new head unit.
I have seen some real half wits get away with replacing radios in early Gs if you get the right stuff for the car you should not have much of a problem in the long run.
Update:
As I said before Oakvil** Infiniti was not much help. All they could do was offer to install a brand new radio for me. I explained to them there was a place in Florida that could repair the radio logic bd for me at a cost of a few hundred dollars, a fraction of the cost of replacing the radio. I asked them if there was a place locally that could do this? They said there was nothing.
I made some more inquiries. Clarion's main office and service center was an 8 minute drive from the Qakvil** Infiniti dealer. I thought I would drop by Clarion and pick their brains about the issue.
Bingo!... They said they were well aware of the problems and would be happy to sell me a service manual for the radio assembly or for $225. they would install an upgrade kit to the assembly that addresses the issues. Nice! Friendly folks with multiple options and solutions at a reasonable price.
Now we are getting somewhere!
For now I have the manual in hand and will update the progress as we proceed.
Once again Infiniti was no help and without a doubt knew all about the Clarion offerings.
I took the radio assembly out last week.
I forgot to take the CD's out of the deck so took the unit back to the car and plugged the three connectors back into the back of the unit to see if I could get the CD's out.
... As soon as I inserted the last connector the radio/CD unit comes alive and out pops a CD????
There is no key in the ignition and the car is off! Interesting to say the least and the first clue to locating the bug.
As you know I could not figure out how to separate the top and bottom units which would allow access to the board in question.
I then handed the unit over to my pal would wanted to have a stab at it.
He called a couple days later. He figured out how to get at the board and was doing a full PD on the board. He discovered something interesting. He had me take some voltage measurements at the car here (he is in another city an hour away).
Well what do you know..... Looks like he may have found the bug, the cause of the parasite drain.
Will update again once we verify.
Just a quick update folks.
The bug appears to be a manufacturing error on the board. My pal made a change to the board. I got the unit back from my pal and installed it last week.
I did some amp checks and confirmed the battery drain problem is gone
The reading between the -post and ground was about .55 (with the battery drain issue), and is now sitting at .07 With the radio fuse out it was/is .05 so a huge improvement.
The only issue I have now is I have lost one feature. If the radio is on when I turn the car off, it is off when I turn the car back on. I then have to physically hit the radio on button to turn the radio back on. May be a memory support voltage or line issue.
Will do some further checks to see if this issue can be corrected. I may have put this bug on the vehicle when taking it apart and reassembling.
Will let you know what I find out. Need to wait for a warmer day as the car is outside and this is Canada...lol
