Mossive wrote:im thinkin droppin my transmission is gonna be tough....right not something the first timer like me can do...crap...i suck at this
It's not really that bad. You just need some serious patience, some long extensions, and a universal joint with the 14mm socket built in is a life saver.
I'd also suggest a second person, if only to help balance the transmission as you lower it on the jack. It's 75+lbs when full of fluid, so you don't wanna drop it on ya.
You may be able to get to the precats with the transmission in from above, but you have to pull the plenum, which can be an equal or greater whore.
