Door panel removal
All things Altima Coupe.
NissNEZ08
Car: 2008 Nissan Altima Coupe 3.5SE (Premium Pkg, Tech Pkg, VDC, CVT & Blk Leather)
Does anyone know how or has anyone removed the door panel? Is it just a snap on and snap off or are there screws involved? Thanks
Rolling Estonian
Car: 2008 Altima Coupe 2.5
1. the light at the bottom of the door snaps out, disconnect the light2. with a flat head screwdriver lift up the bottom end of the window control panel, under that there is a screw3. the silver plastic strip pops out, be very gentle it'll bust easy. under the strip there is a screw4. now the door panel should just pull off
have fun
NissNEZ08
Rolling Estonian wrote:1. the light at the bottom of the door snaps out, disconnect the light2. with a flat head screwdriver lift up the bottom end of the window control panel, under that there is a screw3. the silver plastic strip pops out, be very gentle it'll bust easy. under the strip there is a screw4. now the door panel should just pull off
have fun
Thanks Rollin'
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
I'll offer what help I can...
Mr. Music wrote:To pop off the silver pieces on the door, I used a small flat head screw driver to pry the bottom away from the door panel. Once you can get your fingers behind it, carefully pull it away; there are four or five clips that hold it in place. Once you are done with it, just snap it back in place. I'll see if I can do a mini write up on it, lol...EDIT: OK, here we go...
First: Take your small screw driver to the bottom of the piece.
Then pry it away from the door panel. This will separate a small clip right were I have the screw driver.
Now grab the end of the piece with your finger tips and pull it away some more. Then continue moving up the piece, pulling out the clips. It will take some force to pull them out.
It's off!
To put it back on, snap in the topmost clip, then work your way down.
Done! Hope that helps.
Modified by Mr. Music at 10:12 AM 5/3/2008
have fun
I know of another screw... The plastic trim piece behind the door handle pops off to reveal another screw. Don't have pictures of that though, lol.
Modified by Mr. Music at 7:46 AM 6/1/2008
CDUB 42
Car: 2008 Black Nissan Altima Coupe 3.5 S.E.
Isnt there a bolt behind the door handle. The plastic piece pops out but I cannot remember if there was a bolt there or not.
vballer22
Car: 2008 altima coupe 2.5s
NissNEZ08 wrote:Does anyone know how or has anyone removed the door panel? Is it just a snap on and snap off or are there screws involved? Thanks
I wrote this a while back, scroll halfway down and you'll find the door panel removal pics. Good luck!
Mr. Music
CDUB 42 wrote:Isnt there a bolt behind the door handle. The plastic piece pops out but I cannot remember if there was a bolt there or not.
Yeah, there is a screw in the big hold toward the bottom of the door handle (behind the silver trim piece).
CDUB 42
Im talking about the chrome doorhandle ( the one to open the door) that plastic piece pops out also. Isnt there a bolt behind there.
Rolling Estonian
yep thats the silver strip i was talking about
Mr. Music
CDUB 42 wrote:Im talking about the chrome doorhandle ( the one to open the door) that plastic piece pops out also. Isnt there a bolt behind there.
Yes, there is.
NissNEZ08
Got it! Thanks, you guys rock.
Mark
