oh.aebstract wrote:How much power are you wanting to get? This guy http://allsentra.com/viewtopic.php?f=93&t=770 turbocharged his and dyno'd 420WHP @ 22P.S.I. You could probably run nitrous on that and get quite a bit more. I don't know anything about engine swaps though. Oh and his was a cvt and he converted to 6 speed. Beats me why he payed the extra money to do that though.. I want to do an AWD conversion but I don't have the money ;(
I love how everyone keeps saying there are no parts. There's quite a bit.Just because you cant find it on the self at every store doesnt mean something isnt made, or easy to modify. Example, my car. 2008 SE-R. What parts are available? Here is my List O'Mods:sentrastace wrote:help please.
is it possible to do an engine/motor swap on an 07 sentra 2.0S CVT?
if so, what would you swap it with?
UGH.
ive paid off SOOOO much on my car and i really dont want to trade it for a faster car because i'll just put myself in higher payments, higher insurance, and lose a lot of money because ive done a lot to it/spent a lot of monies on it.
but bottom line is, i want a faster car. (i didnt buy the sentra because it was fast or i wanted to mod it, i bought it because it was the only nissan i could afford, i wanted an alti coupe instead) but i have modded my sentra with every available performance part out there (there arent any!!! just intake and exhaust, performance wise) and now i feel stuck. my car looks good and i may enter it into shows for the visual part but im sick of being under par performance wise.
am i s*** out of luck?
you just listed parts for the SE-R...I don't have the SE-R, i have the 2.0 S and i have installed basically everything available PERFORMANCE wise for the 2.0S which is what i am asking about here....red foot well lights arent going to make my car faster (although i have already installed blue ones)djtorello wrote:
- Crank scraper- Clevite 77 bearings- Blueprinted, knife-edged, balanced crank. (cough 2oz + on 3rd counterweight cough) fixed.- Eagle H beams- Eagle pistons - HDE Sleeves- Spec 07 Head gasket- shaved and milled deck.- 1mm over sized valves- Port and polish head- 5 angle valve job with back cut- Unshrouded the valves on head- Mild cams- Crane springs- Crane Stainless Steel valves, with 10 degree lock- Crane retainers 10 degree- ARP studs- Bi directional sweep cut around spark plug- NGK OEM Iridium spark plug- Osaka Coil packs, 45,000volt, 4 amp less requirement then stock.- Gasket matched Intake manifold (stock)- 2mm Bored out TB (68mm)- Injen intake, Black Spec V, Modified for fitment- Rewound 150amp alt- 160 degree thermostat- Walbro Fuel pump- HDE ground kit- UR lightened crank- HDE modified fuel rail- NEW 41R series battery- Red Painted calipers front and rear- Ceramic pads front and rear- Polished sway bar endlinks- 350Z aluminum control arms, mild modification- Poly filled torque mount- Poly filled engine mounts- Debadged (all but 2 emblems)- RASR tags (Racers Against Street Racing)- Hood light- white LED in Dome light area. Bright as fluck.- Red grill lights- Red foot well lights- White foot well light for courtesy- Soft centered the grill- Silverstar turnsignal bulbs- Silverstar headlight bulbs- LED parking lights- Carbon fiber trim behind inside door panals- Graphite painted rims
08Sentra wrote:It's cool, SentraStace. I love my sentra because it gets me everywhere I need to go, and because i think it looks better than the Civic and the Corolla.
Sometimes though, I do wish for more "Ooomph" in the performance.
That guy that did the Turbo install surely did beef everything up to handle all that boost.
I would love to do the same, but I havent yet become proficient in Manual. So it's automatic for now.
Also, thanks for the info in your posts DjTorello. Learned more about the aftermarket available for out B16's.
I just wish Nissan would release the factory turbo'd 2.0 engine thats in Europe for our cars.
muchas graciasnametakennow wrote:Honestly with the 2.0 and the CVT you can't do much. If you swap, your options are pretty much limited to an SE-R swap.
Definitely going to be more of a hassle than it's worth and very expensive.
I'd keep saving and see if you can afford a "toy" or to get that Alti coupe you want sometime soonish.
Doesnt matter, 90% are custom. No one lists cams, or sleeves, or heads, etc for the 2.5L. If your looking for on the shelf performance, you will always be limiting yourself. Think outside the prius.sentrastace wrote:
ive seen nothing of a EDM 2 liter turbo. If there were such an animal it would be a 2 liter turbo diesel which still wouldnt make it that much faster.08Sentra wrote:It's cool, SentraStace. I love my sentra because it gets me everywhere I need to go, and because i think it looks better than the Civic and the Corolla.
Sorry Sweetheart. Ive been there. luckily i was able to afford a switch. You could probably piece together a custom turbo kit with some research. Otherwise you may just have to be patient.sentrastace wrote:help please.
UGH.
This is why everyone think there are no parts, they are looking specific for the model car they have. A lot of stuff has to be found in other ways, which would probably fit other cars besides what we have.djtorello wrote:
Nissan and Renault share engines to cut down on costs. My MR20 engine is a Frenchy! While the 2.5 is still Nissan.VMPhil wrote:
I know all about the Renault Megane. When some one said Euro immediately starting thinking about the UK Nissan Sentra and thinking to myself "they dont have a Petrol turbo." I didnt think about Renault in France (as i never find myself doing).08Sentra wrote:
In sharing engines, they share platforms and the like. In another thread, it was revealed that the B16 Sentra is almost the same as the Renault Megane. Except they get more engine choices, namely the turbo and the diesels.
There's more info on wiki. Best to look up Renault Megane.
I sure would like to get my hands on one of those turbo'd ones.
+ ^108Sentra wrote:That would be badass if you could do that.
Good luck with the search.
thats a good idea!Spoolin4days wrote:the OP can also keep your eyes open for totaled six-speed Alti's and SE-Rs. Then purchase what you need to swap out of the totaled car, and sell your factory parts to offset the cost.
