did you turn the ignition to ACC and not to the key ON?Get in the vehicle and lock all the doors.
Slowly insert the key into the ignition and then remove the key. do this at least 6 times in 10 seconds (I believe the slow part is on the first time putting the key in because there is no way to do that 6 times in 10 seconds). The tail lamps will flash to indicate the original code was erased.
Turn the ignition to the ACC position.
Press any button on the first remote. (hazard lamps will flash to confirm programming)
To enter additional transmitters, unlock and then lock the doors using the power door lock button on the drivers door.
Press any button on the 2nd transmitter (up to 4 transmitters possible). Hazard lamps will flash to confirm programming.
Open the drivers door and then turn the ignition off.
lemme know because I followed these procedures to re-program BOTH my replacement and original transmittersIMPORTANT: Before entering programming mode, have in possession all of the transmitters you will be using on the vehicle. Once you program the transmitter, all previous codes will be erased from the memory. The other transmitters will not be functional until you program the transmitters again.
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard
Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder
each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press
the button more than one time in the above step. If the button is pressed more than one time, the programming
procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side
power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should
flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Best regards,
Jeremy
We hope this response has sufficiently answered your questions. If not, please do not send another email. Instead, reply to this email or login to your account for a complete archive of all your support requests and responses.
http://support.ikeyless.com/view.php?e= ... m&t=517182
to prove it, i'll give you the link, followed with the page number; i don't need to copy/ paste it because it's the same as what I've said earlier...dammit!after further digging, 2004+ can also be programmed without the consult scanner! http://www.nicoclub.com/FSM/quest/2009_Quest/BL.pdf page BL-69... for shame mod, for shame
