Yup they do. It also has an emblem stating that for those who don't know.Ricko wrote:I know they are marked as Off-Road use only. So I do not think they will pass smog even if you tack it all the way around. I will call Dean and let him know.
did they say you need an alignment to pass inspection? if so thats B.S? I'm a NYS inspector and thats not criteria to pass.ItsEcko06 wrote:So i got the car back from the shop and they said they found the leak and fixed it but when I popped my hood and looked, they didn't fix the headers where I had explained I needed them fixed, apparently I didn't explain it well. I drove it and noticed a difference in sound so they apparently fixed something but not the original problem. They do good work and didn't charge me but now I have to take it back to get those welds done.
My headers don't appear to have black exhaust marks from where it is supposedly leaking but I know I have to get it fixed.
Yea I don't know whats up with the alignment thing, they said they were gonna try to put 2x4s down to get it on the ramp but never did :/
haha no no no. I had it lowered a little while back and just got new tires so I needed an alignment so I took it for both things. Just exhaust leak fix was required for inspection.wade001 wrote: did they say you need an alignment to pass inspection? if so thats B.S? I'm a NYS inspector and thats not criteria to pass.
That is not what I typed. What I wrote was that it is welded on the inside of the flange.wade001 wrote:I've never heard of people welding on the mounting surface, to me it doesnt make sense even with what you say. welding causes irregularities with the surface as it creates an elevated bead. I looked at the picture you linked, I dont see a weld on the mount surface. every aftermarket header I've seen has welds on the outside. I could be wrong but it really doesnt seem to be the right way of doing it.
