DIY snow plow
naladude911
Car: 2001 Infiniti QX4
So I got bored and started googling the internet on how to make your own snow plow. Eventually I found this video...http://www.youtube.com/watch?v=30kY3dmR3msand spent 3 hours making my own one lol. It worked for 5 seconds then broke. After that I used clapboard siding as the "plow" which actually worked. I plowed my whole driveway . Then it broke .
dusred
Car: Previous Q45 owner, 09 Corolla, Ford F250 Diesel truck
Please don't tell me this is real.
I predict another epic Nala thread.
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
hahahahahahahha
Dattebayo
There is a reason snow plows are made of high-impact plastic and 1/4 steel...
I strongly suggest trying again until you get it right. This could get funny.
dusred
. . . . they also float with the road. The guy in the video had it hooked to his ball hitch from the back not mounted directly to his frame.
MellowZ32
Car: Pornographer's car
OMG! next time use your body as the snow plow!
krash
Nala did you say you were planning on majoring in engineering?
Ar878
oh this is gold.
MellowZ32
you have WAY TOO MUCH free time!
Dattebayo
Nala: Engineered to FAIL
Dittoz7
Car: 1997 2f0WtY SE!
How The F Do You Get That From The Video?
Looks Nothing Alike...
S13_love
Nala, whatever bridge you design, let me know.......so I can avoid it.
naladude911
it worked when I added clapboard siding.
naladude911
im buying thishttp://cgi.ebay.com/ebaymotors..._1167
Dattebayo
Dittoz7 wrote:How The F Do You Get That From The Video?
For real, here's a comparison...
Nala:
Rob vanNostrand:
How the hell do these look anything alike?
naladude911
The idea of a DYI plow
Ar878
just because it's the same idea, doesn't mean it has the same functionality.
Dattebayo
SO why didn't you follow the original design?
Razi
Car: Moo
Good luck in school Nala.
raremotive
Car: 04 Infiniti G35
Just a graphic illustration.
Supports, critical...
Moment is torque. Ever seen the stick and rock example where the rock is too heavy to pick up? But if you prop a stick under it and push the stick against a object using leverage and you can pick up the rock with little force.
Same concept, you didn't support the bottom where most of the force. So the stress has to be multiplied the distance it has to travel where the support exists.
Pushing Against vs Moving it.
Ever notice why most plows are angled to one side? It's because it's meant to move the snow off to the side and move on to new snow to be moved.
Your design, as you see I drew red dots at the end of the arrows. That means it stopped. It has no where to go and begin to populate in front of the plow. Then more and more piles up. You reach a point where you can't push any more....
So, angle blade will let you move the snow with a lot less effort and effectively.
The idea of DIY is to research your options. Understand what you are dealing with on a general level. No need to reinvent the wheel when someone has done it already. You can gain valuable experience from them and make a possibly better wheel due to your acquisition of knowledge.
Modified by Rare_f8 at 4:58 PM 1/28/2010
Pwnin O'Brien
Nala, save yourself some money and just forget college. You have a future in snow plows.
s0m3th1ngAZ
Car: 96' Miata
2014 Focus ST
I literally laughed out loud when I opened the thread.ARE YOU f***ING SERIOUS?
An 8 year old could have designed a better snowplow you inbred retard. What went through your head when you made it? "Hmm...all i need is a flat board in front of my truck and it should work...yeah that looks sweet"
Fail....udder udder fail.
Papi Chulo
Car: 72' Datsun 510
Ar878
i hope you're trying to make some sort of joke here. if not, the word you're looking for is 'utter.'
dusred
yvang07
Car: 240sx Zenki
I think 3 hours with the shovel in your first pic would've proved more useful...
The Count
Car: 2012 Nissan Rogue
2006 Dodge Dakota
I cannot believe this did not perform up to expectations.
mmkeller
Car: 2017 Maxima SR
2009 Murano SL
The Nala train has arrived at the station... :moon
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
That s awesome!!!
