DIY pinchweld adapter for floor jack?
ibc
Car: Infiniti M56x
Has anybody here used a hockey puck for a pinchweld adapter for their floor jack? I have many spare hockey pucks, and I could easily saw a groove in a puck. Has anyone tried it? I have not, yet. How wide & deep did you carve the puck's groove? Is a hockey puck durable enough for this purpose, or will it just snap or break? I presume the puck will just sit on my floor jack's (5 inch?) wide flat saddle. Too bad the jack won't fit underneath the car, to jack it up (say) at the pumpkin or front axle. Do you use a puck as a jack-stand pad too?
Ilya
I've never heard of anyone doing this, ever...hahah. Sounds neat.
Before my dad and I built a garage and installed a lift, we just used to use a piece of wood on the jack stand as we lifted the car. I'm sure a puck will be fine...just don't saw all the way through it.
beav626
Car: 2011 M37S
2013 JX35
I used hockey puck on my previous sports cars. They should work great with the M
adeedpb
Car: 2012 M56
2005 BMW X5 4.4i
2005 G35 Sedan - SOLD
1995 Ford Taurus SHO (Supercharged) - SOLD
I Just cut some thick garden hose down the middle to make semi-circle halves, cut the halves into pieces that will fit over the jack stand pressure points. It worked just fine got the M up on all 4 jack stands without bending the pinch weld.
Ilya
My pinchwelds are bent at the mounting point...eh. Is there a reason why this is a concern?
ibc
Car: Infiniti M56x
IlyaKol wrote:My pinchwelds are bent at the mounting point...eh. Is there a reason why this is a concern?
Yeah, cuz previous cars started rusting out there. Grrr.
CRV_33
Car: 2011 Infiniti M56x
I actually thought about doing cutting up a puck as well to use with a floor jack. Any recommendation on what tools to use to cut into it?
adeedpb
Car: 2012 M56
2005 BMW X5 4.4i
Best way would probably be to run it over a table saw with the blade set to the height of the pinch weld.
ibc
Car: Infiniti M56x
My DIY pinch-weld adapter works well...
marosari00
Car: 2012 M56S (Stormie), 2010 Mercedes C300 Sport (Capri)
:dblthumb:
szh
Car: 2018 Tesla Model 3.
ibc wrote:My DIY pinch-weld adapter works well...
Way cool!!
Z
