95silvia14 »
https://forums.nicoclub.com/95silvia14-u40913.html
Wed Apr 01, 2009 4:52 pm
well after my oil pump went out and seeing the cost of new front covers. im not one to trust used critical parts like this especially when i can get the parts cheaper then used front covers. I ordered all my parts from courtesy nissan cost me a grand total of 50.00 and some change shipped. im not going to go into removing the front cover since its covered so many times all ready.
you will need the following tools and parts to preform this job.tools:-freezeoff-12mm socket-cresent wrench-phillips head screwdriver ( both standard and impact)
parts:-oil pump gears (15020-S13001)-valve relief regulator ( 15132-S13001)- oil hat seal (15066-S13007 )
locate the oil pump cover and spray the four phillips head screws and 2 12mm bolts with the freeze off , pb blaster, wd 40 what ever you use
after that locate the regulator cap that looks like this and crack it with the cressent wrench or vise grips.
next you want to take your impact screwdriver and break free the 4-phillips head screws loose. if youve never used a impact screwdriver very easy place it on the screw and hit the end with the hammer.
followed by removing the 2 12mm bolts
after you have those take your cressent wrench and finish removing the regulator set screw when you remove it this will pop out at first just the spring will pop out you will need to stick a pick in the hole to get the plunger to come out.
once you have all the above done your front cover will look like this pull it off and theres the gears staring right at you
remove the two gears and replace them with the new nissan gears.
put the cover back on and torque the philips head to 3 ftlbs and the 2-12mm bolts to 5lbs
now its time to assemble the regulator
when you open the bag containg the parts you get this 2-spring seats1-regulator spring1-retaining screw and washer 1-plunger
take 1 of the spring seats and place it in the bottom of the retaining screw cap. followed by the spring. put the other spring seat in the plunger and place it on to the spring luberacate the whole assembly with oil.
the assembled valve
insert the new valve assembly and tigten the retaining screw to 30 ft pounds
once you do that you are done. i like to then pour some oil threw the strainer pick up hole and rotate the pump by hand for a couple of reveloutions and make sure the oil comes out the output hole
