Since I have a separate starting problem I have the ECM/ECU out of my 1995 J30. I will take a picture and post it to help others like me that don't understand the kick panel every one talks about is on the sidewall and not directly under/behind the glove box.
On the 1995 there is 1 bolt below the ECM and 1 nut on the firewall. The ECM then rotates forward and down out of a large retaining clip on top. It is a tight fit.
Since I can not seem to load a pic directly to the forum or have the image link work, here is a direct URL to the pic:
http://picasaweb.google.com/lh/photo/N9 ... directlink
