Upinsmoke wrote:the ac brackets on the other side of the car, are you talking about the alt adj bracket and what brand alt is it and what is the part number i did this swap on an s13 and there was three drifferent alt u can get thank.
As far as part numbers go? Take the original belt in and ask for two sizes up if possible (or ask for two sizes up from the original; it should be in their computer). I have a Zenki I used the original alt. bracket. I didn't need to modify it, but I did file around the inside a little just to make it easier. Loosen ALL three bolts on the alt. bracket because the alt. wont swivel back in place behind the bracket to tighten it down from the front. Loosen the bolts on the alt bracket and slide the alt bracket a little forward toward the front of the car just enough to crepe the alt behind the bracket so you can tighten it. I couldn't place the alt behind the bracket and tighten everything down. I had to place the alt bracket like normal without the alt behind the alt bracket and backout/unthread the alt bracket bolts that attach to the block, pull forward on the bracket toward the front of the car and slide the alternator in place. The other option inludes grinding various points on the alt and alt bracket. The most obvious one is the lip on the alt bracket because you immediately notice it hitting the alt when you try to swivel it in place. I think people are also using the s14 alt tensioner bolt because it's longer. I'm using one off a ford motor just because it's what was around and worked (I have an s14 but lost the bolt). Note I did this upgrade from the top because I was also replacing some other things or else I would recommend accessing your alt from the bottom.waldo916 wrote:does anyone have pics of the alt bracket that and how it needs to be modified and part numbers of the belt I need for the 125 amp alternator?
Pictures are hosted on nicoclub's old photogallery, so I don't have control over that. In any case, it should be fairly straightforward - you don't really "need" pictures.zachattack_5491 wrote:Yo can we get these pictures fixed? If you no longer have pics, I'm doing this swap this weekend and I can send you mine.
It will probably depend on the actual alternator you buy, but here's one answer that was on the first page:240sx_in_209 wrote:when doing this swap do u need to buy another belt longer belt or can u reuse the same one?
And as an added note, I did this on my ka24de & needed to buy a shorter belt using it w/ the stock pulley. Just fyi.onosqv wrote:Quest pulley is same diameter. I was able to use the same belt in basically the same position - I am underdrive pulley too, don't know if that makes much of a difference. Anyway, there is plenty of slack/adjustment space to make up for a larger or smaller pulley.
I believe the E & DE are interchangeable, they are so damn similar, haha. Don't take my word for it though.
And just for reference about part #'s, autozone has 2 part #'s for the same (basically) alternator for the 97 quest. All s13's are 80amp, so I don't see why they would change anything (doesn't make sense from a manufacturing point of view).
Glad it's helping some ppl
This information is not correct.scruffy63 wrote:Just a quick update for those who don't know. You can use the 1999 nissan quest alt.. I don't remember which other years use that model but its rated at 125 amps. Its physically the same as the 110.
looks like the images aren't there anymore - it was uploaded on the old nico photo hosting stuff.199240sxCoupe wrote:I have a 96 kade in my 92 s13..My question is what do u mean by prep the electrical connector with a 3/8 or larger drill?Do I have to use a diff alternator plug? Or is the s13 plug ok?
I just installed the my Alt in my car and have this issue. But, my valtage goes up to 18 volt.Silent_NightR34 wrote:Sorry to bump this but I just got finished installing this and have a few issues:1)At idle my voltage is like 15.3-15.4 V which i think is pretty damn high.. It stays above 15V with everything on, HIDs, music, heater fans, electric fan, etc.. 2)My battery light is constantly on3)The belt on the alternator looks like its about to jump off.. It's sitting on the edge of the pulley close to the alternator housing with 2 ribs on the main pully part. I'm still using the 5-rib pulley it came with. Is this bad?
I also replaced the 2 prong plug on the alternator with a new one from a Nissan Sentra.. Is it possible that I wired it backwards?
Edit: I swapped the wires that I somehow reversed and now it doesn't charge the car at all again.. wtf.. Same thing happened with my previous stock alternator except the wire for the plug was disconnected and the positive terminal melted/oxidized off..
Modified by Silent_NightR34 at 6:41 PM 4/9/2010
