I say you either tint your headlights like your tails or just remove the lamps.naladude911 wrote:I have a Canadian 2001 QX4 that came with DRL's. How do I disable them? I did the fog light mod but it looks dumb with the DRl's/
It really only takes five minutes (if even) to ground the wire at the DRL module. This will also let you keep full functionality of your high beams. If you want your DRL's back, you just patch the wire back together and it's like it never happened.naladude911 wrote:il just take the bulbs out, there go my highbeams w.e
What relays?naladude911 wrote:I cant reach the module, or the relays.
Well pry it off and then cut the tape. Seriously dude this is starting to get ridiculous.naladude911 wrote:it slides on to this bracket but its been glued to the bracket lol. Il figure something out. The wires are all taped together tho
I am about to attempt this mod right now, I will be taking pics as I go.Pwnin O’Brien wrote:
What relays?
Do you just need to remove the battery to get to the DRL module or is it completely out of reach? If it is inside the quarter panel then you may need to remove the black plastic wheel well trim to get to the unit. There's a thread on NICO somewhere where another member had no problems replacing the DRL module.
Yes, you are right, my mistake. There will be three oval-shaped (the smallest one is more round than oval I suppose) gray colored harnesses going into it (one with seven wires, one with six wires, and one with four wires). Everything else is still the same. Sorry bout that.sc2nr wrote:
From your description, is the DRL Module the clear plastic box attatched to the fender? If so it looks like there is 3 harnesses going into it. not the 2 that was mentioned in your tutorial. is this the correct module?
Like Pwnin said... it's the largest of the three. I just finished the mod and will be posting pictures.naladude911 wrote:which of the three did you unplug? Did you unbolt the box from the fender?
You can just post your pictures in this thread and I'll make a dedicated tutorial with your pics.sc2nr wrote:
Pwnin should I just post my own or did you want to add them to you tutorial? let me know, I'm just running to get the relays for the fog light mod.
Nick
Hey noside85,noside85 wrote:Hello, your write up is very detail, however i have one concern. for my 2001 3.5 pathfinder, on the module i only see two harness, and i dont' see any BLUE wire with the GREEN stripe. can anyone please help? thx alot in advance
THank you for the welcome.Bluewulf73 wrote:noside85 wrote:Hello, your write up is very detail, however i have one concern. for my 2001 3.5 pathfinder, on the module i only see two harness, and i dont' see any BLUE wire with the GREEN stripe. can anyone please help? thx alot in advance
Unfortunately, I also have to agree with noside85. I have a 1998 Pathy with the 3.3l. It ahs two harneses, as you stated in your write-up and after much searching for a Blue with green wire, I have come to the conclusion there is none in my Pathy's DRL wiring harness. There is a sloid blue wire in the smaller of the two harnesses and a blue with red wire...well, I'll just let thephoto do the talking.
Towncivilian wrote:According to [url=<A class=vglnk title="Link added by VigLink" href="http://www.nicoclub.com/FSM/pathfinder/ ... der/el.pdf]page" rel=nofollow vglnk_1344547178050="1"><SPAN>http</SPAN><SPAN>://</SPAN><SPAN>www</SPAN><SPAN>.</SPAN><SPAN>nicoclub</SPAN><SPAN>.</SPAN><SPAN>com</SPAN><SPAN>/</SPAN><SPAN>FSM</SPAN><SPAN>/</SPAN><SPAN>pathfinder</SPAN><SPAN>/</SPAN><SPAN>1998</SPAN><SPAN>_</SPAN><SPAN>Pathfinder</SPAN><SPAN>/</SPAN><SPAN>el</SPAN><SPAN>.</SPAN><SPAN>pdf</SPAN><SPAN>]</SPAN><SPAN>page</SPAN></A> EL-31 of the factory service manual[/url] you're also looking for a blue/green wire. Are you sure you've got the correct harness?
Welcome to NICO.
