Differential cases--interchangeability 03/04 M45 and 04 350Z
marosari00
Car: 2012 M56S (Stormie), 2010 Mercedes C300 Sport (Capri)
Hi all!
Anyone with knowledge as to the interchangeability of the LSD differential case found in the R200 rear end of the 2004 350Z and the open differential case found in the R200 rear end of the 2003/04 M45?
Thanks!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check the output flanges. I bet they are different.
marosari00
maxnix wrote:Check the output flanges. I bet they are different.
The issue is the differential case which is contained inside the differential carrier (AKA gear carrier, or "pumpkin"). The case, AFAIK, is the component that either makes it "open" or "LSD."
The more I research it points that this is the item that determines open differential or limited slip.
In the 350Z, the base model is open differential with an R200 carrier. These can be upgraded by replacing the 2-pinion case to an LSD case. The M45 uses the R200 carrier with an open differential case.
And I may have found a candidate: http://www.quaife.co.uk/Nissan...ntial
Modified by marosari00 at 6:14 PM 12/4/2008
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
marosari00 wrote:And I may have found a candidate: http://www.quaife.co.uk/Nissan...ntial
I referred one of the M mebers to them and he said no dice. But I bet enough $ would produce a solution.
F1SportsFan
Car: 2003 Infiniti M45
There's more info over in this thread: zerothread/146904
