Did some stuff to my car...
ghx407
Car: 1993 240SX KA-T
I got a nice tax refund and decided to splurge some of it on the S13 (with wifey's permission, of course).
My old oil pan's return fitting was leaking a bit and had a weird angle that would sometimes back up the oil and make the turbo smoke. Problem solved with a "new to me" oil pan that I got for free from a buddy, and I did an oil and filter change while I was at it.
Some suspension bushings and the front ball joints were on their last legs so I decided to just replace everything. Got four new ball joints and installed an ES HyperFlex Master Kit. The ES Master Kit install is a pretty tedious job - a bench vise, a propane torch, and a hacksaw will make it a lot easier. The ball joint replacement is cake if you rent the tool from AutoZone.
While the car was on jackstands I replaced/bled the brake fluid with some Castrol GT-LMA and replaced the clutch slave cylinder and its fluid.
I also contacted Jonnie Fraz and ended up with a set of tension rod, fender, and strut tower braces.
Then I went to town on my coolant tank with a milk jug and plastic fusion epoxy to extract some more life from it.
After that, I went to Ebay and got a Nardi knock-off, some 180SX bumper lights, and four XXR 962 17X9 wheels (+35). I kept my old 25mm spacers on to pop them out a bit. Here's some pics:
Dire91
Car: 1997 Nissan 240sx SE
Very nice! I really like the black on white. That coolant tank needs replacing, I do like that plastic fusion think you did though, really creative.
s13_chris
Car: 90 240sx Hatch
Looks great. And just like me, time for new floor mats! And nice engine bay. Clean clean clean :] white hb ftw.
Klits562
Car: white s13 coupe
very nice indeed!
Dazzla
Paint the red stripe on the wheels black, more low low in the front and your GOLDEN!
Car looks awesome though, nice to see a cleanly done chuki! :bigthumb:
ghx407
Thanks for the feedback guys.
Gcustoms
Car: 1992 240sx LE
wow... i ended up doing the exact same thing with my rocker cover XD
lovin the wheels tho... how much you pick them up for?
daves240sx07
Car: 1993 240sx fastback
1991 240sx fastback
2005 Subaru outback
Vary nice.Vary clean in the engine bay.
locoluna825
Car: 90 240sx coupe
shes purdy...
simmode1
Car: Red '95 S14
Mmm... makes me wanna go KA-T... :woot:
RIghtwinger1322
Car: 1992 240sx
reminds me a lot of my car, nice work
ghx407
Gcustoms wrote:lovin the wheels tho... how much you pick them up for?
$550 shipped
Whitecar.
Car: 1993 240sx Fastback
Looks good. I hate to be the one to ask... But did you get your lip recently? If so, where?
240sxjoe92
Car: 1991 Nissan 240sx hatch
Thats really clean...Where did you get that lip from? im looking for one that looks like that or very close to it..Thanks :)
minkl81
Car: 1993 240sx SE
2006 FX35
is your xenon lip painted in black or just original finishing?
i have my xenon lip coming in a week or two and wonder if it needs to be painted.
ghx407
I've had the Xenon lip for about two years; it is not painted.
minkl81
Car: 1993 240sx SE
2006 FX35
i should just leave my lip as it is too than. color matching polyurethane is too expensive and i like them black better.
good to know thanx :dblthumb:
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
looks great, money well spent....
ghx407
I appreciate the comments guys; couldn't have done it without Nico.
Rays_240
Car: 93 sr20det 240sx Hatchback
ghx407 wrote:I also contacted Jonnie Fraz and ended up with a set of tension rod, fender, and strut tower braces.
Jonnie makes fender braces? pics?
ghx407
He does since Fall 2009, but they're not listed on his website. I just sent him an email ordering the fender braces along with the tension rod and strut tower braces and he had everything ready in about two weeks' time. I won't disclose how much I paid for them because of the fact that he is an individual fabricator and I don't want to tie him up to a particular price. However, the price was reasonable. Here's his website: http://www.stealth-custom-fab.com/. BTW, Fraz is awesome to do business with; he kept me up to date on the order's progress, responded to emails quickly, and didn't request payment until the order was ready for shipment.
The install is straightforward; remove outer fender, bolt the brace to the door hinges with the door closed, enlarge an existing hole in the inner fender and drill another one, slip the backing plate into the inner fender through the big square hole, and bolt the brace to the backing plate.
There is no need to jack the car up, but if you do, have the car horizontally level and place the front jackstands under the front crossmember to simulate the weight load on the front axle, thus keeping the unibody in its "normal/natural" position and shape for the install. The job took me about three hours total. There is absolutely no need to remove the headlights. Removing the front bumper before removing the outer fenders made the job a LOT easier.
The pic below is not my car, but those are Jonnie Fraz's fender braces:
simmode1
Car: Red '95 S14
Do you feel any difference with the fender braces? I've always wanted a pair, but I keep hearing that you really need to weld them down for it to work right or be effective...
Dittoz7
Car: 1997 2f0WtY SE!
x2
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
FEDEX ME SOME ALCAPURRIAS POR FAVOR. grassy a**. oh, and some morcilla.
ghx407
There is a definite improvement. I haven't taken the car to the track or anything, but seat of the pants impressions are that the car feels more stable under braking, a lot more solid over dips, the dashboard rattles less over expansion joints, and it requires less corrections through corners taken at spirited speed.
Another improvement is that the sunroof hatch stopped creaking when pulling into my driveway.
The disclaimer is that all the braces and all the suspension bushings were installed at the same time, so I don't know how much of the improvement is specifically due to the fender braces. The car does feel a lot better than before, though.
Also, I haven't been in a car with welded-in fender braces, but it does make sense that welding them in would make them work even better. But it'll be a pain in the neck if you ever need to remove your door.
zach-Ka
Car: 1990 240sx (SR)
I need to pick me up some. I see it being a good investment.
laxands13
Car: 93 240sx Hatchback - Sold and missed
80 280zx - sold
83 Honda Civic Wagon - Current DD, soon to be CA16 powered
man that looks pretty good
simmode1
Car: Red '95 S14
Thanks for the first impressions review of the braces! Plz give us an update the next time you hit the track... It's easy to see the simple logic behind the braces, but I somewhat understand the reasoning behind ppl saying they need to be welded. I'd like to get your first hand input/experience on whether the braces mounting points might bend or deform under track conditions (therefore negating their usefullness) or are they pretty sturdy in your opinion.
Bottom line = I'm gonna get em, but just trying to see if welding them is gonna be worth it for only light track duty and daily driving purposes.
ghx407
Welding will always beat bolting, so it's basically up to you. In any case, practically speaking, the door hinge mounts are not weldable. Removal of the door would require removing the dowel pins in the hinges while the door is mounted to the car, which I figure must be a real pain. Adjustment of the door would be impossible.
To avoid play, I drilled the holes so that the bolts were a real snug fit in them. The bolts are Grade 8 and pretty thick, so I put some LocTite on them and torqued them to 100 ft-lbs.
In general, I seriously doubt that anything other than a collision would bend or deform the fender brace mounting points. A good analogy is that the extreme forces that the tension rods exert through bolts to the LCAs under braking don't deform either part and there is virtually no play where they bolt together.
simmode1
Car: Red '95 S14
That is precisely what I wanted to know! Thanks!
