UPDATE
Been busy ever since I got the truck back.
new window regulators and door felt. Sooooooo much better to drive without the windows banging around!
Old window regulator was missing the spring. No wonder it was hard to roll up and down!
new hood cable. No more sliced fingers!
Tailight fun. Had to replace the reverse lens as it had a crack/big hole in it. Also had to splice in some bulb sockets as a couple of mine were corroded. Can’t afford to get pulled over with the SR now…Probably take it apart and paint the bolt heads black…
Steering wheel being pulled out…… for a Grant hub and wheel. Had to bend the copper shoe horn forward for the horn the work. Also, have to find ~2� long roller pins for the turn signal cancellers. No more getting in the truck and have the wheel crush my legs off!
Autometer gauges (tach, h20 temp, oil psi, volt). Not sure if I like ‘em now. I was trying to match the OE gauges, but I think I want to go all AEM now…
AEM gauges (boost controller, wideband, oil temp)
Coolant port fitting removed to tap for Autometer h20 temp sender. I screwed up and tapped it for a m12x1.5 adapter fitting because the 1/8� NPT sending unit was bottoming out in the housing. After waiting 3 days for the fitting, I couldn’t get it on because the ECU temp sender interfered. :mad Then I went on the website and found out that Autometer has a shallow 1/8� NPT sending unit that’ll clear. Dan’s helping me find a new housing now…
Autometer oil psi sending unit. It interfered with the oil filter when I tried to fit it in place of the stock oil psi sender. I used a GReddy oil filter adapter, but the OE sending unit interfered with the adapter! So I just plugged the OE sending unit hole with a leftover plug from the GReddy adapter.
Front disk brakes on. No progress pics as I was stressing trying to get the truck ready for work today. BIG THANKS TO CLAYTON AND LISA for driving with me down to Mario’s to pick-up the rims (thank you for the deal Mario!). I predict ITB’s and Megasquirt for a certain wagon’s future…
My Chevy rims wouldn’t clear the calipers without a .75� spacer so I had to get new rims (I TOLD YOU I WOULD GET YOUR RIMS BRANDON! Glad your kids like the new wheels ). After all the stress, my buddy Roy offered his extra car to me out of the blue so I could take my time finishing off the brakes…
Isuzu rear disc progress…
I spent 3 hours and 4 cutting discs and didn’t even get one backing disc off. Luckily, Brandon offered to plasma torched them off for me late last night. I wish I had my camera. His L20 turbo motor is gonna rip!
Bearings clean and ready for some grease…
I had to chase the holes for the banjo bolts as Kragen decided to put on the paint extra thick on the threads. :
Sad to see it on stands, but can’t wait for the disc brake goodness! :
Rears are done. Just need to pop in the 280z MC, modify the rod, and plumb it all together!
