I have an lightly modded 750whp R35 GT-R (see :
http://www.gtrlife.com/forums/topic/112 ... s-of-data/ ), but I decided it would be fun to get an R32 project car. With the R32s coming in under the 25 year rule, there are lots of options.
I found one (in Japan), a 1990 R32 with only 70k km, along with a few upgrades.
I was curious to hear some feedback about a few of them.
Using google translate, here are the key ones:
BNR34N1 engine
Tomei Ponkamu
Tomei head gasket 1.2mm
Tomei turbine outlet
BNR34 Gold Brembo
R34 turbine
R34 injector
Tomei INEX slot gasket
Mines VX-ROM
HKS air cleaner
nismo sport clutch
KIT oil catch tank
intake pipe buffing copper two-layer radiator
RS-R muffler
R slit rotor
harmonic drive nismo
Mines 320km meter
It was interesting to me because it appears to have an R34 N1 engine block. The pictures show the regular black valve cover, so I assume it is the R34 N1 block and the original R32 heads. I assume R34 turbine means R34 turbochargers, which is a nice upgrade. It also has R34 injectors, although they are the same size as the stock R32 ones.
"Tomei Ponkamu " must mean Tomei Poncams, although no way to know which ones until I take them out and measure them.
Once I get the car, the first thing I'll change out is the ECU. I will probably put in a Vipec, as I have a couple of Vipecs in my other cars.
Any comments?
Cheers,
Jeff
