I recently bought a 2011 G25X from the Pre-Owned branch of a local Nissan/Inifniti dealership. It was time for my first oil change and this is what I found in my drain pan after I emptied it
https://flic.kr/p/nWBo8L
What appear to be bigger chunks of stuff are actually air bubbles so the photo isn't quite as bad as it appears it could be however I was surprised to see that much stuff come out of the oil pan. Is this normal for a car with 40k miles? It is mostly what I can only describe as sludge with some flecks of what appear to be metallic material. My old car was a 2001 Volvo XC70 with 210k miles and the oil never came out this dirty. That being said I always used Mobil 1 in that car and I think what just drained out of the G was dino or a blend (I'm pretty sure that is what Infiniti dealerships use).
Drain pan was clean before I did the oil change. Dealership claimed they changed the oil along with a multi-point inspection when I bought the car 2 months ago. There was an OEM filter on the car so I am guessing they did change the oil. Everything else that was noted on the list of services performed were indeed done as I could confirm them easily with my own eyes.
Car is pretty much immaculate for a 3 yr old car, 2 previous owners (leases) and CarFax is clean. The car appears to be very well taken care of compared to a handful of other pre-owned cars I test drove. It drives perfect, no issues, doesn't consume oil, 26.5mpg avg with mileage being 75/25 (70mph highway/city driving). I put about 500-600 miles on the car a week.
I am now running Mobil 1 5W30 with a Mobil 1 EP filter. I guess I will see what the oil looks like at my next change. Car is still under factory warranty so I am wondering if I should have this looked at while it is still covered although I know a dealership won't do much in terms of being proactive; they will probably tell me it is normal and send me on my way.
Comments? Thoughts? Thanks in advance.
