I want OEM HID. i guess it is out of the question. The dealer offer to help me install aftermarket HID. But it is illegal to drive around?philipa_240sx wrote:Nissan used to pre-wire all trim levels of some models for fog lights and sell a seperate fog light kit with the lights, a new turn signal stalk with the fog light switch, and mounting hardware. My '03 Altima 2.5S was a good example and I added the fog lights using said kit.
This practice appears to have changed since Nissan has now deleted the fog light wiring from the harness on lower trim levels of the Rogue. I am sure it similar for other features as well. This is possibly a cost saving measure... copper wire is getting very expensive nowadays. I was disappointed when I found this out as it makes upgrades more difficult. Now you must add wiring, relays, external switches on the dash, etc. I can see some dealers not wanting to touch this to avoid warranty issues, liability, etc.
Some of the features you want can be done quite with a bit of work:
- Rear spoiler: this is an OEM accessory that any dealer can install- Fog lights: use OEM lights, add a relay, wiring, and a switch on the dash (the OE switch likely cannot be retrofitted)- Rear cargo light: wire an aftermarket dome light and install it on the roof in the hatch area. The OEM version will require more work as it's installed on the rear hatch. This means replacing the plastic trim panel on the hatch with one that has the cargo light and adding the wiring.- Xenon HID headlamps: OEM Xenon lamps are going to be very difficult and expensive to retrofit. Your only option here is aftermarket HID's. The dealer will not install these due to liability issues again... aftermarket HID's are not legal for road use in the US or Canada.- Rearview mirror with compass and anti-glare: The mirror can be purchased as a replacement part. All you need to do is add the wiring to power it.- Wheels and tires: The OEM wheels have TPMS sensors that need to be removed and installed on your new wheels. Not all aftermarket wheels will accept TPMS sensors so be sure they will work before purchasing. OEM wheels from another recent model Nissan should work as well. Note: if you change the TPMS sensors (new or used), they have to be programmed into the Rogue's TPMS computer for them to work. This has to be done by a Nissan dealer.
Good luck!
Aftermarket HID's are not DOT (US) or Transport Canada (Canada) approved. The problem is putting an HID bulb in an halogen lamp reflector may result in glare and does not meet the requirements for beam pattern and beam cut-off mandated by the gov't. You will fail any sort of gov't inspection and you can likely be pulled over and ticketed for them as well. Aftermarket HID's are your easiest and cheapest option however.AznJohn22 wrote:
How come I see some sedan with HID lights and different color?philipa_240sx wrote:
OEM HID is not impossible, just very expensive. I have done some research on it and posted a bunch info awhile back. Here it is again
- Headlamp assemblies with bulbs, ballasts and hardware but not including wiring are $1300/pair. - Wiring is fairly straightforward. The HID headlamp connects to the same wires as the Halogen one. Replace the Halogen lamp connector (type H11) with a 2pin connector for the HID ballast. It's Nissan's connector #J-48817-122. This is the hard part as Nissan dealers supposedly have replacement connectors for service... but you have to convince them to sell you one! If not, you have to search the auto salvage yards.- The OEM HID manual headlamp leveller cannot be made operational without alot of wiring and the necessary parts. The leveller is used to adjust the beam to compensate for glare when the vehicle is heavily loaded at the rear. Suffice to say you can run the HID's without the leveller and leave them in a fixed position.
