Rex »
https://forums.nicoclub.com/rex-u6324.html
Wed Jan 09, 2013 9:19 am
I only suggested the battery, as I had a similar issue in my 95 Lexus SC400. The car started, drove and did all other things fine, the Trip worked, the odometer worked even the temp gauge worked all same digital type display across the bottom of the dash. I had the battery tested and they told me it was only 16 months old, it wasn't the battery. Fast forward 3-4 months, and the car is slow to start on cold mornings, but starts every time even after sitting for days.
I decide I'm going to just replace the battery, and the are willing to check it 1 more time, and after a solid 5 minutes of connecting, disconnecting & re-connecting the battery tester they decide the battery is bad.
Next they subtly accused me of swapping the battery and insist I must return the exact same battery, because batteries don't go dead like this in <2 years.
Anywhoo, after the new battery was installed, the clock started working fine.
I realize this may not be your case, but my car started every day for 5 months after the clock stopped. I hate thinking of the extra burden I put on the alternator all that time.
