94_240sx »
https://forums.nicoclub.com/94-240sx-u26401.html
Sat Nov 29, 2008 7:51 am
Great job!!! Yeah, this is definitely one of the best DCC write ups out there. DCC is next mod for my car too, but I've been putting it off because it looks like there's no way I can install the air mix motor without pulling out the dash. Is there enough space through radio hole? When I saw it, I was like 'NO WAY!!!'
I had a chance to get ahold of USDM air box, so I played with it a little to figure out exact length for the linkage. I should have posted this already, so you can get a perfect length. I'll do the write up with a lot of pics for sure when I do mine. Anyway, here we go.
This is s13 air box on the car.
It's out.
Manual climate control closes and opens the air mix door with a cable like this. Some people who don't have OEM linkage keep this wire and connect it to the motor. You can take it out by removing a couple of screws, so don't cut it just in case you want to go back to manual CC when you can't make the DCC work at all.
OP didn't mention about the air mix motor mounting process. I think you have to fabricate a bracket to mount air mix motor to the air box. These are the mounting points, but it's not a direct bolt on matter.
There are two ways you can mount the air mix motor. This is on the left side of the air box.
This is on the right side of the air box. I don't know which side it shoud go. I need to figure it out.
Now, length of linkage rod is adjustable, so I played with it a little.
This is perfect length. If your DCC set came with the OEM linkage, count the thread and set the rod this way. If you are several teeth off, air mix door won't open and close perfectly and it's possible you will overload the motor.
OP fabriacted this part with a metal coat hanger. I can give you guys exact length, so you can make one for yourself. I'll try to post it tonight. OP, why did you have to fabricate it? Was it simply missing or OEM linkage didn't work well?
One more thing, there's another sensor that goes to near front bumper. It's an outside ambient temp sensor which is different from sun load sensor. OP didn't mention about it either. Anyone knows about it? I think DCC still works without it.
Modified by 94_240sx at 10:14 AM 11/29/2008
