i recently finished wiring my swap. I run fuel lines to fuel rail. In at fuel rail and out on FPR side. I double check my wiring. I plugged canister vacuum from intake manifold, since i dont have one.
Car starts up after cranking some time and then it runs for a bit and dies. I checked timing and distributor. For AIC valve i have a small filter since i run intake opposite direction. FRP is stock, and the vacuum is connected to intake manifold. Im guessing to check fuel pressure next, see if my fuel pump is not supporting.
My starter is starting to go out
Let me know if you have suggestions, thanks
