I'm Daniel from Las Vegas. I just got into working on cars last year, and i'm loving every second of it. i just last month sold my EG hatch
because i wanted to go sideways. So i bought an sr motor from a friend and set about making a daily driver with tons of help from Traverse Hilsabeck, a Pro Am drifter http://www.facebook.com/pages/Traverse- ... 7038747896. This is my first ground up build, my first Nissan, my first RWD, and my first boosted car.
Mods right now:
Motor was resealed new gaskets, t28 turbo, godspeed fmic, full 3" exhaust with cat delete, adjustable fuel pressure regulator, battery relocated to trunk, godspeed radiator, samco hoses, warlbro 255lph fuel pump, VLSD, 18" knock of rims w/ black powder coat, short throw shifter w/ supra knob, Driveshaft Shop one-piece driveshaft.
Right now all the bushings are bad, so there's an Energy kit on the way, as well as tein outer tie rods, new ball joints, and new boots for the steering rack. Eventually, when i get enough cash, i'll replace the windshield and get a BOV. It's currently only running the stock 7psi and surging, but i want to raise it to ten with a boost controller eventually.
EDIT: found pictures of when i first bought the car as a shell w no suspension/engine
of course he took the center garnish and exhaust off, i removed the stupid extra nissan badge and stickers
not a bad interior
dash cracked to hell, no gauge cluster (bought a dual cam cluster from traverse)
stripped the interior pretty much including the hub in the picture
everything you see in this picture was taken out. the only things he left in the bay were a few hardlines, a blown brake booster, and that's about it
as you can (kind of) see, there's no suspension. He removed everything including the front and rear links, ties, brackets, EVERYTHING. It took five people to get it on a tow truck. Not only that, but the stock brakes he put on so he wouldn't have to give up the z32 front brakes he had were put on the wrong side and the rear ones are bad. the guy was ridiculously greedy (he just wanted to sell all the other parts, wouldn't budge an inch) and left almost nothing in the car. not to mention the wiring is still giving me headaches.
it's all good now, i have the car, my project is started
