Factual »
https://forums.nicoclub.com/factual-u72580.html
Thu Aug 02, 2007 10:18 am
Ok, I have a Nissan Altima GLE 2001. I was driving the car one Friday and the car was running fine (besides this weird sound I kept hearing). All of sudden the car just cut off; I tried to crank it up but it cut off every time. I towed the car to a supposed Nissan Specialist Auto Repair Shop. They checked the oil and there was no oil in my car (I know I’m a retard for not getting my oil changed regularly). They suggested that I could have a timing chain issue and told me to start off by getting an oil change and a major tune up. So I did ($250.00). After they finished the oil change and tune up, the car sounded extremely loud when I attempted to accelerate but wasn’t getting any power at all (I could barely get it up to 60 mph). It also began hesitating and idling extremely bad. I drove the car home the best I could (it overheated a few times) and then took it to the dealership on Monday. Before I took it to the dealership I went by Autozone and got a diagnostics test done. They told me I had a cylinder misfire on cylinder 1 (P0301). I explained this to the mechanic at the dealership and described my problem to him. The dealership had the car for 3 days and then they told me that I needed a new Airflow Meter. Thinking that would solve my problem I had them put in a new one ($800.00). After they replaced the Airflow meter, the tech told me that I also needed new Catalytic Converters and that’s why my car was running sluggish. I asked if my timing chain could’ve slipped and he said no and that he checked it and it was in perfect timing. I then figured I would take it to a muffler shop the following Monday and have them replace the Cats. So I paid for the Airflow Meter repair and attempted to drive the car home. I drove 2 miles and the car cut off and would not turn back on. I then had the car towed back to the dealership. The following Monday they informed me that the car cut off because my front Catalytic converter was clogged and that I could have a problem with my fuel pump or fuel regulator. I ordered a new Catalytic Converter online and then drove my car to the muffler repair shop when the parts arrived. The guy at the muffler shop informed that the Front Catalytic Converter was fine and that the rear Catalytic Converter was actually clogged (the opposite of what the dealership told me) but that the Auto Parts Company had actually sent me a Rear Catalytic Converter instead of a Front one. He also said that the weird noise I was hearing was from the Heat Fold (or something like that) which he also welded back into place. The muffle mechanic was also nice enough to check the diagnostics for me again and the diagnostics is still reading a P0301 (Cylinder 1 Misfire). The muffler mechanic told me that I had probably had a bad coil pack and that’s why the car was hesitating, idling and having problems accelerating. Now the funny thing about that is, when I originally took my car to the dealership, the tech asked me “when was the last time I had a tune up?” I said 3 days ago. The mechanic at the dealership then showed me one of my coil packs and said that when he pulled it out, it mysteriously came apart. He then checked the spark plug and saw that it was new so I guess he figured the coil pack was fine. Now I'm trying to find out since my car is still running sluggish and hesitating, would it be more likely that the coil pack is no good or that the fuel pump needs replacing? I’m tired of guessing what my problem is and I really need my car to get back and forth to work. Any assistance would be greatly appreciated. Thanks in advance.
P.S. Sorry for the long post
