My 2011 came with conventional oil from the factory, not synthetic. I'm not sure that the 2012 would be any different if the engine was not modified.tranh2 wrote:Hello all,
Just a question about engine oil and the CVT fluid. I've read that its recommended to change the engine oil at the break-in period, should the CVT fluid be changed as well? Also, in another oil thread, someone mentioned that the rogue comes with synthetic engine oil. Is this correct and should I just stick with synthetic when I do the break-in period oil change?
Thanks!
engine makers put conventional right from that start. thats the break in method. you bought it with conventional already in theretranh2 wrote:So are you saying I should use conventional oil on the next oil change (ie. break-in oil change) regardless of type of oil in there now? Then switchover to synthetic after that? To make it makes sense to change at break-in to get rid of the crap that in there. The manual says breakin period is approx. 2000km and doesn't say anything about oil change or type of oil. Can I safely assume that there are no additives in the oil out of the factory?
20k is a little over-kill but to each his own.Towncivilian wrote:I'd use conventional oil up to 20k miles.
I'd change the CVT/differentials/transfer case/power steering fluids around 15 or 20k as well using OEM fluid (for the CVT) and synthetic fluids everywhere else.
I would use the oil that is recommend by the manufacturer. I'm not a huge fan of synthetic oil for most people because it's overkill; your vehicle will most likely die from other causes well before the conventional oil you put inside causes an actual problem. No one can deny it is a better oil, but it also comes at a higher price. The question is really, does the better oil (synthetic) provide a benefit that is only measurable or actually noticeable? Because of this my opinion is that I recommend changing your fluids/filter as per the intervals from the manufacturer. Extreme conditions are exceptions, but most people do not live in an area with extreme conditions.tranh2 wrote:So are you saying I should use conventional oil on the next oil change (ie. break-in oil change) regardless of type of oil in there now? Then switchover to synthetic after that? To make it makes sense to change at break-in to get rid of the crap that in there. The manual says breakin period is approx. 2000km and doesn't say anything about oil change or type of oil. Can I safely assume that there are no additives in the oil out of the factory?
sorry, but i had to number the important things i needed to address in your post lolTrevorK wrote: 1). I would use the oil that is recommend by the manufacturer.
2). I'm not a huge fan of synthetic oil for most people because it's overkill; your vehicle will most likely die from other causes well before the conventional oil you put inside causes an actual problem.
3). No one can deny it is a better oil, but it also comes at a higher price. The question is really, does the better oil (synthetic) provide a benefit that is only measurable or actually noticeable?
4). Because of this my opinion is that I recommend changing your fluids/filter as per the intervals from the manufacturer. Extreme conditions are exceptions, but most people do not live in an area with extreme conditions.
5). You can google to find out if Nissan puts any additives in the oil
and its not always about where one lives. its got to do with:TrevorK wrote: Extreme conditions are exceptions, but most people do not live in an area with extreme conditions.
Buying Nissan products is about buying products that they state are equivalent (or greater) than their specifications. Unless you are confident in selecting an oil that meets the manufacturers specifications then yes, you should purchase their oil. While this may not seem hard or difficult to some it is to others.ImStricken wrote:1). the engine oil that nissan sells (which is branded with NISSAN) is simply re-bottled oil. it could be a contract with any major oil producer. every auto maker does that. so buy spending the extra money on nissan branded oil, your essentially going against your #3 idea: "does the better oil (synthetic) provide a benefit that is only measurable or actually noticeable? "
I'll address these together.2). you think synthetic is overkill? how so? how is better lubrication overkill? or do you mean for the rogue engine specifically? i personally dont use synthetic on our rogue, but i certainly wouldnt say a think to someone who does. its better oil, it has more stable properties and has amazing lubrication properties.
3). will the oil provide a benefit that is noticeable? no. will it provide measurable results? no. but i must say oil isnt made for instant results/satisfaction. the one thing thinner oil will do instantly is leak from seals/gaskets that are shot. otherwise oil isnt designed for instant performance. its made to extend the life of your engine over-time. its made to extent the life of seals, gaskets, etc. so things that you cant see are actually conditioned better with the use of higher performance oils like synth/ester.
You contradict yourself when you mention that BMW offers a 1 year oil change option which undoubtedly lowers their service revenue. Manufacturers provide a maintenance schedule based on the people who engineered the vehicle, if you think that you're in a better position to determine that maintenance schedule than them by all means do it.4). that you need to be careful of as well. manufacturers understand that often people who use the dealers for service will pay big money over time for services such as oil changes. if manufacturers start stating to change your oil at twice the 3,000miles interval, that means their dealers will be making HALF the money they used too. thats not in their best interest. (but many manufacturers like BMW/BENZ started recommended and offering 10,000-15,000 mile oil changes using synth oil.) i simply use my own method: name brand conventional oil at the cheapest price with regular filter = usually costs me $23 total/ changed every 5,000 miles.
We're dealing with a Nissan Rogue here and half the points you mention are not applicable. Nissan makes an extreme maintenance schedule to deal with the "extreme" scenarios and if you fall into it (they do provide examples) then you should consider following it.and its not always about where one lives. its got to do with:
does one tow?
is your engine naturally aspirated or not(t/s-charged)?
off road or on road?
how hard do you drive the car?
city use, or highway, or both?
how long does your car sit before being used?
type of engine? (VQ37VHR: the VVEL system almost requires the Ester oil)
again, you do realize that nissan DOES NOT make its own filters, oils, etc? they outsource it from companies like fram, purolator, wix, etc?TrevorK wrote:Buying Nissan products is about buying products that they state are equivalent (or greater) than their specifications. Unless you are confident in selecting an oil that meets the manufacturers specifications then yes, you should purchase their oil. While this may not seem hard or difficult to some it is to others. It's the same reason you should purchase a Nissan oil filter unless you're confident in purchasing one that is equivalent. It's not spending "extra money"; it is selecting the appropriate part for the job. If you can't select an appropriate aftermarket part then the OEM part is always going to be acceptable.
there is no speculation here. synth is a better oil. better oil cools the engine better. better oil protects the vital seals better. better oil creates less sludge. better oil takes away a lot of the friction produced by an engine. THERE IS NO SPECULATION lolNo one is denying that synthetic is a better oil, It's easy to sit here and speculate (and it is speculating) that "oh, the engine itself will be in better condition" but that's irrelevant to the overall life of most vehicles.
i didnt contradict myself. bmw offers 15,000 mile oil change because its "free" and apart of their service that comes with certain cars. you paid for it already in the price of the car, dont worry. plus bmw had contracts with Mobil1 to supplement any losses. PLus when at a bmw/benz dealer the customer who does have to pay for his oil change every 10-15k he pays $80-$150. dont worry mate. they are making their "every 3000mile oil change" worth there are no free gifts in this world, you should know that. but i will call nissan on its bluff of making you change your oil every 3,000miles. its a proven fact that todays engines do NOT have to change their oil every 3,000-3,500. we have different cross hatching on our cylinder walls, and tighter clearances that allow for less material wear & less carbon buildup within our oil. BUT TELL YOU TO COME EVERY 3,000MILES MAKES THEM SERIOUS MONEY.You contradict yourself when you mention that BMW offers a 1 year oil change option which undoubtedly lowers their service revenue. Manufacturers provide a maintenance schedule based on the people who engineered the vehicle, if you think that you're in a better position to determine that maintenance schedule than them by all means do it. They give you their opinion on the best way to maintain your vehicle. You obviously trust their opinion given you bought their engineering marvel for a reason.
i tow a trailer with a racebike & gear( 1500lbs+), i do drive off-road at time. long driveway thats all sand. and at times i drive it hard. i drive in nyc traffic constantly, etc. so yes, just because its a Rogue- doesnt mean it wont see abuse.We're dealing with a Nissan Rogue here and half the points you mention are not applicable. Nissan makes an extreme maintenance schedule to deal with the "extreme" scenarios and if you fall into it (they do provide examples) then you should consider following it.
you can bring in your own filter - im 99% sure they will use it problem free. i know for a fact mobil1 makes an extended service filterkerrton wrote:Good points, and good idea keeping on topic. There is an existing thread on this that covers a lot of the debate and we could add to it:
has-anyone-changed-to-synthetic-oil-yet-t304676.html
...and that is disappointing that Nissan is using the cheap filters with cardboard ends, I won't be pushing it much past 3500 miles/6 months.
ImStricken wrote:again, you do realize that nissan DOES NOT make its own filters, oils, etc? they outsource it from companies like fram, purolator, wix, etc?
Any part you purchase from an OEM is the "right" and "appropriate" part for the use it is intended. Is it the best part available? No. But that doesn't mean it is not the "right" or "appropriate" part according to the engineers who designed the vehicle.JUST BECAUSE IT SAYS NISSAN DOESNT MEAN ITS THE "RIGHT" or "APPROPRIATE" tool for any job.
Again, there is no denying that synthetic is a better oil. If you reread my post you'll find out that it is pure speculation on your part of the condition of an engine after 120,000 miles and how that condition relates to the type of oil put inside. It is also speculation on your part that synthetic oil will actually make a difference in the lifespan of an engine in relation to the vehicle.there is no speculation here. synth is a better oil. better oil cools the engine better. better oil protects the vital seals better. better oil creates less sludge. better oil takes away a lot of the friction produced by an engine. THERE IS NO SPECULATION lol
I just thought I'd double check - did you mean the 6000KM above (as that's the regular interval)? Or should that be 12,000KM?kerrton wrote:Regarding synthetic, I just got the word from my Nissan dealership today that they are approved to recommend 6 month/6000 km change intervals for their Mobil 1 Full Synthetic motor oil, with tax it will be almost exactly $100, x2 changes per year = $200 total which is what I paid for the regular, more frequence oil change.
"there is no denying that synthetic is a better oil" - how then, if its not going to make a difference in the lifespan of the engine? you make no sense. WHY DO YOU FEEL THAT SYNTH IS A BETTER OIL - BUT YET IT WONT MAKE THE ENGINE LAST LONGER.TrevorK wrote:Again, there is no denying that synthetic is a better oil. If you reread my post you'll find out that it is pure speculation on your part of the condition of an engine after 120,000 miles and how that condition relates to the type of oil put inside. It is also speculation on your part that synthetic oil will actually make a difference in the lifespan of an engine in relation to the vehicle.
i also use purolator. the pics i have up are for my g37 enginejcircus wrote:Hello everyone! New Rogue owner here. I just did my first oil change (I like to do my own maintenance), but the puralotor I purchased (as recommended by purolator) was the exact same size as the nissan filter...
L14612
ImSticken, the one you show in your comparison is larger? What is the purolator part number in that pic?
thanks!
You keep missing the point; while synthetic oil is a better oil it will not add to the lifespan of the vehicle because for 99% of people the car is long gone to the junkyard before the type of oil you use comes into play. You focus on the engine's lifespan when in reality the engine is a piece to a much larger puzzle and not the sole determining factor behind life of the vehicle and that's what is important.ImStricken wrote:"there is no denying that synthetic is a better oil" - how then, if its not going to make a difference in the lifespan of the engine? you make no sense. WHY DO YOU FEEL THAT SYNTH IS A BETTER OIL - BUT YET IT WONT MAKE THE ENGINE LAST LONGER.
if you call me bluff, that synth is going to actually make a difference in the lifespan of an engine.- prove me wrong. because from what i know, synth doesnt cake up inside as easily as conventional - and that sludge IS what kills engines. by having a better barrier between piston rings & cylinder walls IS whats going to prolong its service life.
dude you are DEAD wrong. most people send their cars to the junk yard because the engine or tranny is shot. YOU KNOW HOW I KNOW THAT? I MANAGE A JUNK YARD lol. i dont care what the other issues like RUST, accident, etc come into play. we are not talking about those reasons. we are talking about ENGINE & TRANNY OIL AND THE NUMBER ONE REASON ENGINES DIE IS BECAUSE OF SLUDGE OR WORN PISTON RINGS. (and thats where your oil comes into play)TrevorK wrote: while synthetic oil is a better oil it will not add to the lifespan of the vehicle because for 99% of people the car is long gone to the junkyard before the type of oil you use comes into play. Who cares about the benefits of synthetic oil when those benefits do not increase the lifespan of the vehicle or create any other actual noticeable difference during the life of the vehicle?
wrong again mate. 91 isnt "cleaner" than 87. and 112(race fuel) isnt cleaner than 91. octane prevents early ignition thats all. its basically a retardant.Again, it's the same as using 91 Octane in the Rogue. While not having done any research I assume it will burn cleaner than 87 octane.
So let me get this straight. Your evidence that a properly maintained engine using conventional oil is having issues directly related to conventional vs synthetic is based on cars that are sent to the junkyard? Really?ImStricken wrote:dude you are DEAD wrong. most people send their cars to the junk yard because the engine or tranny is shot. YOU KNOW HOW I KNOW THAT? I MANAGE A JUNK YARD lol. i dont care what the other issues like RUST, accident, etc come into play. we are not talking about those reasons. we are talking about ENGINE & TRANNY OIL AND THE NUMBER ONE REASON ENGINES DIE IS BECAUSE OF SLUDGE OR WORN PISTON RINGS. (and thats where your oil comes into play)
the higher quality oils create better barriers for the moving parts, thus reducing wear, thus increasing engine life. they also dont sludge up as fast.
Here we go again. I clearly state "I have done no research" and "take this only as an example" yet receive an arrogant reply.wrong again mate. 91 isnt "cleaner" than 87. and 112(race fuel) isnt cleaner than 91. octane prevents early ignition thats all. its basically a retardant.
engines all run different compression ratio's. if you compress pure gasoline enough it explodes easily. so when the basic 4 cycle engine(which we have) hit its 2nd cycle (1intake, 2compression, 3power, 4exhuast) which is compression, and the fuel explodes to early due to the compression = you have pre-ignition that will not allow the engine to run right, and will cause serious knock, and will ruin your engine. so manufacturers realized that 87 fuel is pretty much the lowest our cars can run on without developing pinging & knocking- because of the explosiveness of gasoline. but our knock sensors adjust to the timing of the ignition of the fuel. so we are fine to run 87 in a car that says super, and to run super in a car that says 87. nothing to do with cleanliness
If I was in a situation with my dealer to do what you're doing (synthetic oil changes at 6 months/12K (I assume you meant 12K)) for the same price as two conventional oil changes I would too just for the sheer fact I save a large amount of my time. I think it's great they will stand behind the extended interval because not only does it help you but you also generate less waste for the environment which would really add up if more people did it.kerrton wrote:In the case of using synthetic oil in my car, its a no-brainer. The yearly costs are actually lower for me, and the potential benefits are much higher with a superior lubricant. Like you said Trevor, you have to look not only at the benefits, but how significant is the benefit and it seems to me that synth is significantly better.
