deeohgee81 »
https://forums.nicoclub.com/deeohgee81-u45335.html
Thu Nov 14, 2013 6:32 pm
Car: 2008 Nissan Rogue AWD
Miles: ~129,000
So, my Rogue is having issues and i think they are related to the CVT. It only happens on long trips (1hr on highway or more).
2 months ago I heard a whistling sound and the car would not be able to sustain regular speed (cruise control). It would then kick me off cruise. When i pressed the accelerator, it would only go to a predetermined RPM (maybe 4000) and it would not be able to accelerate, simply sustain speed. Things would get worse up to the point that i could get passed on by 18-wheelers. I would then pull over to a gas station let the car rest a few minutes, and when i got back on the road, it would go back to normal. If the trip was longer, i would have to do the same stop/rest routine every so often.
I read in these forums about the CVT transmission oil being "Aerated". I checked the level when cold and it was above the hash marks, so i removed ~1 quart and the problem seemed to disappear.
Yesterday a related yet different problem started. At night, during a short 20min drive on the interestate, i could feel the RPM jerking during cruise control. Normally the car settles at a certain RPM and cruises on it. This time, it was going maybe +/- 100 RPM back and forth. For example. If it wanted to be at 3000RPM, it would go to 3100, then jerk down to 2900, then back to 3100, back and forth (not smoot, jerky). It then went away, but i knew it was not normal.
Today during a 2hr drive on the interstate, i could vaguely hear a whistle (oh no right?) But it was not as loud as before. The car kicked me off cruise control, and this time the cruise SET light was blinking...i couldnt go back to cruise. I then pulled over and after a few minutes of rest the problem went away. I could tell the car was having transmission problems again.
On the way back (another 2hr interstate drive) the car started well, but slowly got worse. This time the RPM were not limited (i could press the accelerator and get the car to go to 7k RPM if i wanted) but the car had trouble accelerating. 2 months ago, i couldnt get it to accelerate. Today it was able to, but it was struggling. I also noticed that it needed 2700RPM to maintain 75MPH, and i think this was a little high (Normally around 2200RPM). After a while, the car needed 3200RPM to maintain the 75MPH.
I have changed the CVT fluid at 120,000miles (first change by the dealer at 36000 miles). I changed it myself, simply opened the drain pan bolt and refilled using Nissan NS2 CVT oil. I never experienced any problems up until 127,000 miles. I live in Atlanta, GA.
Any ideas what it might be? I am so frustrated by this that if i dont find a fix, i will never buy a nissan again. I had sentra, altima, and now rogue. I like them, but now all come with CVT and i dont have a good experience to go by.
Any suggestions would be greatly appreciated.
