maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Wed Aug 24, 2005 10:24 am
The problem is that when the boot gets torn; it slings all the grease out of the boot, and lets water and other contaminants into the joint.
Don't bother just replacing the CV joints, get new axles. 2 axles from somewhere like pepboys will cost you about $60 a piece (for remanufactured axles).
It is possible to do it yourself, but the main obstacle will be getting the axle nut off as it is torqued up to 231 ft/lbs. If you have access to an impact wrench, this won't be a problem.
You can go for a while with the torn boots, but as with most things on a car...the sooner you get it replaced, the better. It all really depends on how hard/far you drive the car as to how long they will last. I would say you should be ok for a month at least.
So if you don't feel comfortable replacing them yourself; call around to a few repair shops in your area and get quotes on replacing both front axles, and go from there.
And welcome to NICO!
