NutriaforBreakfast »
https://forums.nicoclub.com/nutriaforbreakfast-u77129.html
Wed Jul 16, 2008 10:46 am
You want to buy the complete halfshaft assembly to install. Nissan OEM isexpensive but Autozone, Oreilly's etc are about 1/2 of that price.
Unless you are a experienced mechanic with a lot of tools anda good shop you will be unable to change out the just the bootand bearings.
You also want to change out the seal going into the transmissiontoo. A friend needs to hold the shaft while you put on the brakecaliper, put on the large nut etc so the seal doesnt get warped during reassembly.
Now is also a good time to check the power stearing since the shaft is out of the way and look for other problems. If you neednew brakes put them on now since you have the wheel and caliperoff.
