mr0x »
https://forums.nicoclub.com/mr0x-u155427.html
Sat Mar 06, 2010 7:52 pm
I worked on it last night and finished the job.
To take the CV out, I hammered on the part until it seperated a little bit. I drove in a small piece of metal to create a bigger wedge and then used my four way as a wedge to hammer the rest of it out. Maybe it would have been all easier with a nice set of pry bars and an air hammer but I was under there for a good hour or two getting the thing to move.
Got those two out.
I was expecting tranny fluid to gush all out but nothing came out. Maybe it's because I had it on jacks on both sides and the oil went somewhere else.
I didn't change the oil seal. The dealer said I would only get it on Tuesday if I ordered it on Friday. So, I just decided to reuse the old one.
I took it for a test drive and everything seemed to work good.
Here are the set of comments or things I found weird- the shop manual says remove the brake hose clip but I couldn't figure out what the brake hose clip was. It wasn't in any of the illustrations. It made the job a lot harder since the two hoses were really tight when I got the CV axle into and out of the hub. I thought it was the one that connected a hose to the bottom of the hub and was taking it out but the bolt head broke off. So, yeah, couldn't get that one out.- the manual talks about clips but I did the passenger side and it didn't have anything like that. I think it's talking about the driver's side on all of page 872.- the shop manual does not mention the torque for the bolts to the lower strut mounting bolts.
So, actually easy job but I made it take a whole day.Tools needed are- 36mm socket for the wheel bearing nut - 10, 12, 16, 17mm sockets- I used an 1/2" air impact wrench. - Jack that can raise it high and jack stands- Metal hammer and some pry bars- 12mm ratcheting flare wrench for the 3 nuts
Mechanic quoted me $120 for parts and around $100 for labor. I got the part from Autozone for $70 + taxes (- $10 core). But, since this was my first axle replacement, it took the whole day (two half days) and I got really really dirty with all the grease.
Modified by mr0x at 10:00 PM 3/6/2010
