C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu Jul 22, 2004 6:16 am
The bolt holes need to be drilled out so that as the manifold expands, the studs from the head do not get sheared off. The holes should be progressively larger as you get to the outer cylinders. Though, you can also get away with ust using larger holes all around, but then it requires that you are a bit more careful in lining up the mani to the head as you tighten the mani to the head. According to Corky bell, I believe it is 0.1 inch larger for every foot from the center of the manifold.
