I definitely get better mileage with Shell 93 than BP 93, and I definitely get better mileage with Country Mark 93 than Shell 93. In previous mileage threads,
http://www.toptiergas.com/ has been referenced. Click on retailers and you will see that BP and Sunoco are not on the list (Sunoco Canada used to be, so apparently the list is maintained).
ETA: Note that I don't know whether or not detergent has much to do with mileage, especially not from tank to tank (IE, manufacturer recommended amounts of detergents may help over time, but not as soon as you fill your tank). As such, these may not be the best places for mileage, but should be best for your engine. Additionally, I live near the Country Mark refineries, and Country Mark uses only US sourced oil. Either of these things could have to do with the better mileage (the oil not being out of the ground as long before it is refined or the gasoline not being stored as long before it is pumped and used), but I'm only thinking aloud, not claiming to be an expert..
