Do a leak down test or compression test. If its getting or got hot and running like crap, might me the head gasket.POSz32 wrote:Hey there new to forum. Got a problem an figured yall could help. I have a 1990 300zx n/a bought the car a few weeks back. Had an issues when the car got hott. It would sputter/ miss like hell during mid throttle but if i floor it it would be fine. Changed fuel pump. New plugs fuel filter. O2 sensors. Now the car has gotten worse it does it right on start up has a fluctuating idle wants to die at idle still sputters at mid throttle. Kinda sound like a 2 step launch control. Its pissing me off just dumping money into it and i need some help i have a video but i dont know how to upload it. Any help would be greatly appreciated.
Your 16.3 one is out of spec, that will cause the sputter/popping. If you have the old style, they all will fail soon. Personally, just plan to go to the new style. Money well spent if you plan on keeping the car.POSz32 wrote:All injector read about 12 to 13 ohms exept one is at 16.3 or something.
If you have an injector at 16 ohms, it is bad, plain and simple. It may still be working, but its not working correctly, and your car will run like crap until it is replaced. Not cleaned or rebuilt, replaced. Our injectors are picky, especially the older style(square top) due to the ethanol blends in the gas. The higher the number gets, the more fuel it will dump in the engine, till one day it will either stop open or shut.POSz32 wrote:Just found a decent fuel leak after passenger side fpr.
Are you sure you did the compression test right (engine warm, full battery, etc.)? 120 psi is very low for a vg30de engine.POSz32 wrote:Compressions all around at 120psi
