Crazzy idle. And sputter. Miss fire idk pissin me off.
KiDoZ
Car: Nissan 300ZX NA non turbo
Due to time constraints for me. A few days. But total time several hours. You will need a plenum gasket as well. Oh. And if it has never been removed before. You may have to get the gasket grinded off the plenum. I had to grind mine off. Caution. I had shop do that for me. Don't want to ruin plenum. Buy the injectors from someone or ask on Hereford website to purchase. Someone knows who to buy them off. I don't recall I got mine locally off someone. Do the work yourself and save. A shop will charge a lot. Sorry can't answer cost for you. I'd say.
KiDoZ
POSz32 wrote:Well idk its going to my buddy's shop tomorrow morning im just gonna let him find the issue if he cant pin point it than i will change the injectors ill let yall know why he says tomorrow. How long did it take you to do your injectors? And how much did everything cost you?
Hey there. So what your buddy find out about car?
Did you search this site for injectors?
POSz32
Car: 1990 300zx
No its still in his garage ill find out some time tomorrow. Thanks for checking in havent looked at injectors. But im looking at this 383 stroker in my garage and thinking its time to do a vicious engine swap lol
POSz32
Car: 1990 300zx
Ok the garage has no idea whats going on. So i got it back in my garage today. I pulled the timing covers off and the belt looks fine has good tension looks like the water pump been replaced so i would guess that the timing belt has been also. The cam gear grooves line up with the backing plate but the whitle lines on the belt dont match to anything is this ok?
yodawill2000
Car: 94 Infiniti J30
I found one on Ebay for 29 shipped. (Knock Off)
Same issue.
Fine on start up and bogging down huge when it reaches temp.
re-soldered everything inside the maf, No fix.
Put the replacement MAF in and it runs like a champ !
POSz32
Car: 1990 300zx
Lol i just ordered a ebay mass last night 34$
POSz32
Car: 1990 300zx
Had one at autozone waited 2 days for it and it was faulty
POSz32
Car: 1990 300zx
I've been thinking thats the problem exaust is smoking black when messing up
POSz32
Car: 1990 300zx
Anyone know about my timing belt question
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
The white lines on the timing belt and the marks on the rear timing cover only line up every so many revolution (like 1000 or something). It only matters that they all line up when you're installing a new one. After that they probably won't ever line up again that you'll see. Smoking black means your running super rich, did you check the injectors yet?
Also, ebay MAFs almost never work right so don't be surprised if it acts faulty. Only OEM MAFs work good, you should just pick up a good used one for $80-100
POSz32
Car: 1990 300zx
Nah man i havent. I am stuck on it being the mass air flow if have to wait till next Friday to buy new injectors anyways. The white lines dont line up at all. Just the grooves on the gears line up with backing plate.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Yeah, the lines will never line up again that you will see. Every like 182 rotations or some crazy crap like that.
Only the N62 MAF will work. Some places even go as far as to put an N62 sticker on a different MAF. There's a guide somewhere to tell the difference. I can't recall where, though.
POSz32
Car: 1990 300zx
So how do i tell if it is on timing. Just buy a light?
nissanfreak12
Car: 92 300zx 2+2 TT
Only way to actually if its on timing is to count the cogs between the marks. That is a sure fire way to know for sure. If you are blowing black smoke, and you even said you have an injector at more than 14 ohms, you need a new injector. These injectors are known for going out, causing issues, just problems all around.
The other things that will cause an overly rich situation is CTS, O2 sensors, MAF, etc.. The MAF WILL cause a CEL. Does the ecu show a code 55 when you check for codes? Possible an ECU issue if not. You can also put it in mode II to check O2 sensors.
POSz32
Car: 1990 300zx
Yes it does show 55
KiDoZ
When I recall my issues just a few weeks ago. And now that I think of it. The tip of the exhaust got black from the car running to rich. It smelled bad to. All my problems and test came up with injectors as the cause. As much as it is hard to believe that some of them ohm at between 12-14 ohms and you think they are good. Chances are they are misleading you and in fact are bad. It happen to me. I can ohm out bad ones at 12-14 ohms. It happens. Today my car runs extremely good. I kid you not. If one injector is high. I would just get them done. All 6pack of them. Your car will thank you.
One injector is enough to make your car lose total power and run sluggish.
One injector.
We here to support fellow Z owners.
Lets get your Z running
nissanfreak12
POSz32 wrote:Yes it does show 55
Ok, good start. What plugs do you have in the car? If you have code 55, and black smoke, its either going to be that bad injector or an o-ring has gone bad and causing more fuel to get in the engine. MAF will throw a code, will not let the car rev past 2500, and a ton of other issues, but it will show a code.
Just for sh*ts and giggles, is it a stock MAF that has N62 on it? Or was it replaced by a cheap knock off?
POSz32
Car: 1990 300zx
Hey guys if you wanted to know what the issue was it was the maf. Still plan on doing injectors some time soon before Import alliance. I appreciate all the help.
