Rakesh_mp »
https://forums.nicoclub.com/rakesh-mp-u197597.html
Mon Apr 23, 2012 3:09 am
I have searched everywhere for a solution for my problem and in the process have learned a great deal about my car. I am not a mechanic by any means, but just by searching through this forum I have learned a lot about my 93 Q45 which I purchased a few months ago. Car has 110k miles on it, there was a leak in the radiator, so with the help of nicoclub, I replaced the radiator, changed oil and filter, changed fuel filter, replaced a cracked vacuum hose(90 degree hose next to the throttle body), cleaned the MAF sensor, replaced the air filter and cleaned inside of the throttle body with b12 choke/TB cleaner. I learned how to get to the ECM and read the codes and code 11 and code 54 are being thrown.
I have checked both of the connectors on the CPS, sprayed electric cleaner and they seem fine, no corrosion. I still get the error code. When I drive the car, it lacks power during take-off and at standstill there is vibration while it's in drive. Vibration is a lot less when its in park or neutral. It sometimes starts jumping then shuts off when reaching red lights. Also, on the highway around speed of 70mph, I can press the accelerator and it will accelerate fine but when i let off the gas, the car starts jumping. It's almost as if the car is shutting off and on, like it does when I am approaching a red light.
Could bad injectors or bad spark plugs cause code 11 to be thrown and cause the car to behave the way it does or do I need to replace the CPS(almost a cost of a quarter of what I paid for the car, lol)? Does code 54 relate to the car bucking and vibration problem or is that something that needs to looked at differently?
