Amadauss1 »
https://forums.nicoclub.com/amadauss1-u161364.html
Mon Sep 13, 2010 11:50 am
Have a 2 1/2 ton floor jack and can use this if necessary but same thing here, would use a block of wood because jack part that goes against car is not the biggest by any stretch. Sorry to labor this point and great pic swim shark, but if I just want to jack up one side and let the other rest on tires and then use the stock jack that came with car to get it up in the air, if I do not have the attachement or a piece of rubber or anything to compensate to put on my jack stands to fit into that grove along the bottom of the car, where would be safest place to put the jack stand? do you have a picture or can you give me a dimension or measurement like 3 inches here or there on frame side? Asking a lot, but just don't want to have it come crashing down. Thank you for all the help.
PS: my next question is going to be about the door locks, passenger side door and rear driver side door both do not open. Can use the keyless to get into car on other two doors but those just will not unlock.
