by shanez » Tue Jul 24, 2012 6:25 am
Ok, so here's there rundown:
93 240sx w/redtop
everything stock besides front mount and exhaust and hks bov and walbro pump.
I hooked up my aftermarket temp gauge and I am only reading MAYBE 150* after driving it for quite some time. I can hit boost (~8-9psi) doing 1/4 to 1/2 throttle and it picks up like a raped ape with no issues. I also get a funky small misfire when idling.
Then when I try to speed up full throttle or down shift and punch it, my car bogs out like a mofo with no power. So, things I've checked:
injectors: 11.8ohms on all four
TPS set to 0.5v when car is off and throttle closed
MAF showing 1.5v at idle
Plugs gapped to .035 on bkre6 NGK
I am just wondering if the coolant temp not getting up to normal operating temp would cause it to run s*** like that. The needle on my stock temp gauge goes up a little over 1/4 of the way too so I think it's deffinately running to cool. Any ideas?
