Coolant leak at the factory weld on the metal coolant hose "T"..
looks to be 5/8" heater hose metal pipe with a 'T' that branches off with a ~5/16" hose.
I had a coolant leak this morning and found it was from the factory weld area. I was thinking of just welding it back up shut.. but I may just replace.
This is on driver side, behind intake plenum.. harnesses the harness what looks to be a coolant temp sensor on rear of head (driver)
Anyone able to help me find this part number?
You can see in the pic where the hole is.. its pin sized..
Anyone lend a hand with finding me this part new through Infiniti or atleast a part microfiche so i can find it myself?
Thanks!
Kong
